Old 12-17-2005, 01:20 AM   #1
mark69k20
mark69k20's Avatar
Re: MOTORHEADS--69' 307ci tell me about it...
Lots of good info... you guys that got new carbs and intakes... How hard was it to do away with the auto choke? How does it work? This is what is left after the origional plastic one came apart. Thanks!
**Off topic Dallas Cowboys cheerleaders in Kuwait!
mark69k20 is offline   Reply With Quote
Old 12-17-2005, 12:47 PM   #2
Tynee
I miss this truck.
Tynee's Avatar
Not bad at all. I went with an Edelbrock 1406 electric choke carb. I believe it was two wires. Getting the carb on and running right was nothing. Getting the Dizzy back in after I screwed up the re-install was what I had trouble with in the whole process. That could be because I was learning as I went, though. Didn't think very far ahead when I started pulling old parts out.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-17-2005, 02:31 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've seen a heap load of Chevy engines and never seen a single carb intake that interfered with an HEI. Usually, it's tunnel rams and the like which have multiple carbs/and or extreme high rise that cause interference with large body HEI distributors.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
