de-arch springs
I'm getting ready to de-arch my springs on the 71 gmc to lower it down to about 4.5", will the springs go back into the same bracket they came out of or will I half to move the brackets after they are de-arch?
Re: de-arch springs
Yes they will bolt right back on. You shocks will be a bit long. You also might want to trim your bump stop down. I did and it rode much better with the extra 1" travel.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: de-arch springs
Thanks MARIO, did you get shorter shocks put on?
Outlandish Trends - FL
Re: de-arch springs
You can get shorter shocks from a lot of places. I'm running Doetsch Tech and am very happy with them. Also recommend the shock relocator kit from CPP. It will help bring your shock angle back to a more upright position which will in turn help the ride quality.
-Bret 67 short-fleet sold! |
