Old 12-21-2005, 01:24 PM   #1
JonnyTechMech
STOP! Hamma time!!!
JonnyTechMech's Avatar
Angry It's a fact, my engine is cracked
Well it was all good during the summer. But when a cold spell came through in Nov. I got caught slippin. It was below freezing for about a week and I raise my hand as say I did it… “I did not confirm that I had enough antifreeze in the truck”! Now the block is cracked !!!! Looks like someone took a 10lb slug to it, on both sides just above the oil pan. It’s what I get for working two gigs and not paying close attention to everything.
Well….Game ON!!!! I need some practical advice and prices of a potential 350 engine I plan to replace my scraped 305. I was going to drop a 327 with Vortec heads and all mods necessary. But I don’t have time for that. I don’t have money for a LT model as well. So I’m going for a Vortec 350 model 90-98; if they exist that late. So please lend me your idea’s on junkyard searches (what to look for/identify) or reasonable priced creates. I’m sticking with the TBI and the 90 models only; unless 2000-02 offer something I can just drop in with minimal changes. I looking to spend in the range of $800 -1000.00 on the long block alone. I hope to get the “Intake and TBI” with it but not get taken for a ride at the junk yard; so I need to now the average price of such a motor.
My don’t list:
Don’t want a BB.
“ “ “ a SB bigger than a 400.
“ “ “ another 305
“ “ “ change to Carb
“ “ “ change to TPI
“ “ “ older model SB
“ “ “ nothin but a chevy
Why the limitations and being picky, Well….. I’m on a budget, need a quick and easy drop in, want to keep moderate MPG, and I want to upgrade while I have the opportunity.
So lets have it!!! Teach me somethin new! What would you do?
Thanks in advance.
Plan your work and work your plan!!!, or pitty da fool!!
87 GMC BaseTrim, 305 under the wrench/TH400/
92 Chevy 1500, 350,TH700R4 sittin on dubs
JonnyTechMech is offline   Reply With Quote
Old 12-21-2005, 01:57 PM   #2
Izzy
Trucker.
Izzy's Avatar
Re: It's a fact, my engine is cracked
TBI was 87-95, Vortec was 96-98(99/00 on the SUV's).
Izzy is offline   Reply With Quote
Old 12-21-2005, 03:18 PM   #3
JonnyTechMech
STOP! Hamma time!!!
Ok.. But could you not use TBI on a Vortec engine or is Vortec strictly TPI?
Old 12-21-2005, 03:29 PM   #4
JonnyTechMech
STOP! Hamma time!!!
duh!!! I knew the answer to my own question. Bigarmzz is selling just the part I would need to get away with TBI and Vortec combo. I gotta get more sleep. Thanks Izzy, now I know where to start looking.
Old 12-22-2005, 09:44 AM   #5
bigarmzz
bigarmzz's Avatar
yeah, you can run a newer vortec motor in your truck, no problem..
you just need the big ol' $$$ intake that gmpp makes, or you could use a carberated intake and use an adapter (although i really dont recommend that)
check out this web site
http://thirdgen.org/techbb2/forumdis...?s=&forumid=17
that link should take ya to there "tbi tech board", its for third generation camaro's, but the same concept applys
good luck man!
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 12-22-2005, 10:30 AM   #6
Jonboy
Slots go on anything!
I looked into doing the same thing to my 90 Suburban. I found a couple 350 Vortec engines around here for $750. I figured I would have $1100-1200 in it by the time i picked up the intake and built the EGR valve.
You can also pick up a 350 premium long block at Blaines for $640 + core. I put one in my 87 SWB I had a couple of years ago, and it still runs great. They usually try to hose you on the core, but a full core charge is only $400. They come with a 12/12 warranty, too.
If you need any help with the swap and whatnot, I am in Arlington.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-27-2005, 04:21 PM   #7
JonnyTechMech
STOP! Hamma time!!!
Thanks Jonboy, for the info. I'll look into Blaines for the block. I'm not confident in the junkyard engines, unless I going to rebuild it. I have no time for that or traveling to south Texas to mess with Scroggin Dickeys. In my hood, I can't pull/replace an engine without HOA breathing down my neck or I would definitely take you up on a helping hand. I'll just have to pull it to the country in Tyler Texas where I got access to air tools. I got some more upgrades to make like dropping it, installing a 700R4, replacing the suspension and disk break job. I’ll have to wait until spring to jump on it.
Anyone else, who can offer more helpful info, would be greatly appreciated.
