Old 12-22-2005, 10:54 AM   #1
aitch
aitch's Avatar
Rear sway bar?
I've been thinking about installing a rear sway bar on my 69 GMC. When I am done, like these things ever get done, I'll be running 2 1/2 drop spindles in front, 4 inch drop coils in the rear.
Looking for input on whether this is a good mod or not. What sway bar did you use, Camero, other? How does it improve handling?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 12-22-2005, 11:22 AM   #2
flatbedchev
flatbedchev's Avatar
Re: Rear sway bar?
i read somewhere that you can use the rear sway bar out of a late 70's Camaro. All you need to do is make a spacer for each side. But I also thought someone made a rear sway bar for the 67-72 trucks
flatbedchev is offline   Reply With Quote
Old 12-22-2005, 11:40 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Rear sway bar?
Many vendors on this site carry the front and rear sway bars.. performance online has em right now for 229 that includes both bars and everything to mount them..www.performanceonline.com
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-22-2005, 02:06 PM   #4
rauto13
saving one more
rauto13's Avatar
Re: Rear sway bar?
I have a rear sway bar from Classic Performance and I love it. Every truck I will every get will have front and rear sway bars. A little info on my truck is 72 long wide with front and rear sway bars, front dropped 1 inch with drop springs and rear lowered 3 inches with drop springs. I also have an adjustable track bar, polyurethane cab mounts, and a close ratio steering box. The truck handles like a dream.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 12-22-2005, 03:43 PM   #5
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Rear sway bar?
Originally Posted by rauto13
I have a rear sway bar from Classic Performance and I love it. The truck handles like a dream.
So can you tell us the difference in handling from having just a front bar to having bars at both ends? I ask this because on another truck I had the truck would push into corners more [became "tight" as racers say] when I put the big bar on front. I never did add a rear bar to see if the balance improved to more neutral.
Now that I have built an air ride chassis, I am wondering if the rear bar makes for a big difference in handling. I have the ECE front sway bar installed now, but the truck isn't back on the road yet, so I don't know how it will handle.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 12-22-2005, 05:50 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
Re: Rear sway bar?
Rear made a noticable difference. At least on a Burb. Here's a link to what I did (Camaro rear bar)
Frizzle Fry is offline   Reply With Quote
Old 12-22-2005, 09:51 PM   #7
aitch
aitch's Avatar
Re: Rear sway bar?
Frizzle and all, thanks for the imput. Think I'll start shopping for a Camero sway bar.
Frizzle are those Coddington Timeless rims in your avatar?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
Old 12-23-2005, 12:04 AM   #8
Frizzle Fry
Re: Rear sway bar?
I would recommend the bigger IROC bar. At least for my Burb, it feels like it could use a little more. The stock bar might be just right for a truck though. You can easily upgrade later if you decide to.
Those are just Torq Thrust IIs blown up in PS
