Member
I need a lower ratio rear end instead of the stump puller on my 67 C-20; also
Are there any sources for complete steel beds for 67-72 C-20 long boxes? On the rear end, it drives on the highway, like it's in 2nd gear, while in 3rd. Anything over 40 mph sounds like it's overreving! I have searched through many parts suppliers on line for sheetmetal parts but only can find small repair panels for the bed floor. Mine has rust at the ends where it is rolled. Project location is Spokane, Washington. Last edited by Locked; 12-26-2005 at 03:51 PM. |
Jostrans68
Re: Axels & Steel Beds
location?
![]() former 67-72 now with a 96 silverado |
its all about the +6 inches
what gear do you have in your 67?
Designated A-hole!
I'm gonna move this to the correct forum for you.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Lower ratio gears are stump-pullers in my book.The higher the number,the lower the gear because the number is compared to one.1:1 is final drive/high gear,right?
Special K - You have the right thought process, we can all get it confused by perspective. The process goes bonkers when I tell you I have a really low rear end, and it gets misinterpreted as low meaning deep, power or acceleration versus speed, versus low meaning highway gears.
For my .02, I have a 3.55 in the Longhorn, don't recall anything lower numerically, or more in a highway mode for the 3/4 ton. Most common is 3:73 or 4:10, probably some 4:56 in trucks with a 6 cylinder. To Locked you need to find out what you have in order to know where to go. The other suggestion is to review and revise your profile with a general location, or specific, so locals can contact you. Don't know of any reproduction bed materials for LWB, or Longhorns, I have one more 8' CO bed that has a few issues on the floor. I plan to dismember the sides as they are nice, as well as the front end panel, and get them in the rafters for some other day. Would sell it whole, but it is not a rust free cherry piece. I have one of those on a 72 Cheyenne from CA. The other deal on rears is to consider a taller tire which will drop your effective ratio and make the highway a bit more tolerable. If you add tire diameter, it will effectively change that ratio. You need to use a diameter of the OEM tire, and you can ratio it to the taller tire, i.e. 29"/32" = .90625, use that as the multiplier on a 4.10 and you get a 3.71. Problem is most 3/4 tons will run a fairly tall unit as stock, so your replacement tire may not have that total impact as the example. Hope this helps a bit. LILREDGMC |
3.4 ton also had 3.42 rear gears which is a great overall highway setup.
You can get a Dana 61 with 3:08s in it, and just weld on new spring/coil mounts.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
#9 | |
lil red, actually the 4.10 and 4.56 are most common, with a 3.54 or so with big blocks... nothing else was offered. Not stock anyways. (onless we wanna start talkin the 5.13-ish gears too)
