Old 08-11-2003, 02:02 AM   #26
outlaw
have someone apply the brakes loosen the bleeder screw and see how much pressure the brake fluid has and do the same to the other side if they are differant then you know where your problem lies
outlaw is offline   Reply With Quote
Old 08-18-2003, 11:39 PM   #27
pa_snowman
all this about the calipers and hoses, did anyone think that the propotioning might be bad or stuck? i have a 79 3/4 ton van that had one go bad. when you applied the brakes it would turn right then go straight, when you released the brakes it would try to go left then straight. i changed both rotors, calipers, wheel bearings and still had the problem until i changed the valve.
i know they never go bad, right- but MINE DID!
jim gallagher
pa_snowman is offline   Reply With Quote
Old 12-24-2005, 05:01 PM   #28
pa_snowman
Re: Well..new tires and alignment, STILL veers violently!! HELP!
clean the caliper mounts every time you remove the calipers. they slide on the resting points and if their is rust or dirt there it will cause the caliper to hangup and drag.
jim gallagher
Old 12-24-2005, 06:13 PM   #29
dwcsr
Hollister Road Co.
dwcsr's Avatar
I had the same thing on a 92 GMC 1500 and it was brake line after I changed everything else. The line was colapsed inside and would not let fluid return to the master making the caliper drag. I would change them both and be done with it.
Old 12-24-2005, 06:27 PM   #30
N2TRUX
Happy to be here
N2TRUX's Avatar
Digging up bones? This thread was started in 2003.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-24-2005, 10:46 PM   #31
Boog
laying low
Boog's Avatar
And the original poster either never found his problem or sold the truck or gave up or just didn't want to finally post what the problem was?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-25-2005, 08:22 AM   #32
MOTHERTRUCKERS
2003? surely it is fixed by now.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 12-26-2005, 12:39 AM   #33
SCOTI
SCOTI's Avatar
He's not around anymore. I remember reading about his welcome wearing thin as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-26-2005, 01:30 PM   #34
XXL
Seņor Member
XXL's Avatar
Prop valve works from front to rear. There's a single front line that comes out, and then splits afterward to feed the 2 front corners. Not likely that a prop valve could affect a single side.
And N2TRUX... of course, it's Xmas. We're bored.
XXL is offline   Reply With Quote
Old 12-26-2005, 04:22 PM   #35
N2TRUX
Happy to be here
N2TRUX's Avatar
Appearently you don't know Tim very well. My guess is he is still considering his options on what to do here.
Old 12-26-2005, 05:14 PM   #36
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I saw Tim over at FSC. A character for sure!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-29-2005, 05:32 PM   #37
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
He had some issues with agirl friend or something have not seen him for quite some time...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-30-2005, 08:36 PM   #38
screamin_c102
screamin_c102's Avatar
Maybe he "Veered Violently" into the path of an on-coming 18 wheeler, or off a cliff, and was never heard from again......
Brakes are not something you half-ass or do on the cheap. I'd rather be able to stop than go any day of the week.
screamin_c102 is offline   Reply With Quote
Old 12-31-2005, 11:31 AM   #39
mister honey
I miss TIMSPEED!
Mike
mister honey is offline   Reply With Quote
Old 01-08-2006, 01:37 AM   #40
DroppedZ84
DroppedZ84's Avatar
I heard he was "offed"
DroppedZ84 is offline   Reply With Quote
