1ton lca question!
what wears on the one ton lca? is it the nut or the shaft? or are they designed to not wear, and never get replaced?
Fabricate till you "puke"
Re: 1ton lca question!
Both pcs wear, it just depends on how much wear as to replacement parts used. I have gotten lucky enough to replace bushings only & tighten up an old truck for a while. If you have lots of slop in the arms, you would be best to change shafts & bushings tho....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#3 | |
Happy to be here
![]() Join Date: Mar 2000
