12-04-2005, 10:55 PM | #1 |
steering arm
Have any of you tried to remove the steering arm? If so how did you accomplish this. I have tried all day to get this thing off and it wont budge. If anyone of you have had success stories with this please fill me in. I have a 1971 k10 4x4 if this is any help.
12-04-2005, 11:12 PM | #2 |
Re: steering arm
you need an pitman arm puller most parts stores have them for loan spay some pb blaster on it and start whreching on it it come right off
12-04-2005, 11:40 PM | #3 |
Re: steering arm
should I expect some resistance. This thing hasn't budged at all.
12-04-2005, 11:43 PM | #4 |
Re: steering arm
It's probably not going to come off w/o a puller...
I just bought one for about $20.00.. Well worthe the $$$ Hope it helps
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
12-05-2005, 12:00 AM | #5 |
Re: steering arm
Is it called pit arm puller? I went on a couple of local auto parts shop and put in pit arm puller and nothing came up.
12-05-2005, 12:27 AM | #6 |
Re: steering arm
idk thats what i call it lol alot of time you got to go to the store to find them
12-05-2005, 03:21 AM | #7 |
A guy with a truck
Re: steering arm
Pitman arm puller. Yes you will need it. After whackin' the arm with a hammer for a few hours, you'll be angry you didn't get the puller sooner. (Guess how I know)
Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-05-2005, 03:56 PM | #8 |
It's a catastrophic success.
Re: steering arm
A pic
12-05-2005, 05:38 PM | #9 |
WTB this ad
Re: steering arm
A pitman arm puller will not remove a steering arm. That is why it called a pitman arm puller not a pitman/steering arm puller. Are you needing to remove the steering arm on a 4x4? The steering arm is the part that is held on with 3 nuts to the steering knuckle. The pitman arm is held on with one nut to the steering box. You can remove the steering arm without a puller. Your steering arm has conical shaped washers, so by pulling up on it all you will succeed in doing is makeing it tighter. Take the three nuts off the steering arm. Get a large socket that is bigger in diameter than the conical washer. Hold the socket on top of the arm and strike it with a large hammer. The impact will shock (or vibrate) the washer right out. It shouldn't take more than one or two hits per washer. It's the same principle as using two hammers to remove a steering wheel (when a puller is unavailable). A large hammer can be placed on the center shaft of the column and then struck with another hammer of equal or greater size. The impact will make the steering wheel pop off in your lap. I have seen this question posted here several times before and I have seen many well intentioned people suggest pullers, torches, and other implements of destruction. Most of the time I think they end up ruining their steering knuckle and having to replace it. Somebody prove me wrong here! I have done this and I know it works. You can have that steering arm off in less than five minutes if you do it the way I have described. I think this could go in the FAQs. Anyone?
If a BFH worked on my K10 it ought to work for you. |
12-06-2005, 10:47 AM | #10 |
Re: steering arm
The differences
12-06-2005, 10:51 AM | #11 |
Re: steering arm
sorry wrong pic
12-27-2005, 03:00 AM | #12 | |
Re: steering arm
Hope you have the same results.
12-27-2005, 10:19 AM | #13 |
Re: steering arm
It would be a good one for the FAQ if there weren't all the wrong answers before yours see ten. If someone starts reading this and doesn't finish, they are gonna run down and get a puller from the parts store that will be useless to them. This is a good example for why we made a 4x4 disscussion forum.
Hope it works for him. Sounds easy. A lot of guys have beat on those things all day. |
12-27-2005, 02:49 PM | #14 |
Nobody rides free
Re: steering arm
Yup we beat mine for a while, although not with the socket trick, that would have worked good. We ended up firing up the torch & burned that SOB off. Gotta give the socket a try next time
'71 C10 LWB 400SB/350TH '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
12-27-2005, 09:10 PM | #15 |
Re: steering arm
I have done the socket trick and also another thing I found to work is to hit the side of the arm with a hammer beside the conical washer a couple of times untill the washer works itself up. This works if you dont have a socket at your side.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
12-29-2005, 01:28 AM | #16 |
Re: steering arm
Those washers are also split, I usually hammer a thin screwdriver into the slot and they spread and pull right out. Then you'll still have pound on the arm to get it off. The first time is tricky but now it's fairly easy.
