12-28-2005, 05:02 PM | #1 |
Look What I Bought..Opinions wanted on head upgrade
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8024684868
I couldn't resist. I'm beginning to compile the parts I need for my engine rebuild and stumbled into this. I wasn't planning to go quite so high performance but talked myself into buying it anyway. Maybe I'll hotrod a little more than I had originally planned. My questions are: Will it be ok to use rebuilt stock heads? If a head upgrade is necessary, what would you recommend? Thanks, JKR
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey**** 68' C10 Short Step (rebuilding as we speak) 72' Custom Camper (wrecked, parting out) 79' C10 Fleet (rough, parting out) 97' C1500 Short Step Custom (DD) 97' Kawaski VN800a Customized 99' Z71 Silverado 04' Suzuki Volusia |
12-28-2005, 05:18 PM | #2 |
And Don't Call Me Shirley
Re: Look What I Bought..Opinions wanted on head upgrade
WOW, that is beautiful! Nice find.
The 383 cranks are inexpensive nowadays. How about a 9 to 1 383 with SR Torquer heads and a nice smooth hydraulic roller cam ground for grunt. I really have no idea what you like or don't like or where you're headed with your engine rebuild. But big smooth motors with lotsa torque is cool in an old truck. Just my .02.....
Rick Tucker 1969 C20/Custom Camper (the Green Machine)Sold 1970 GMC 4000 COE (future Ramp Truck) 1972 K10 Longbed (restoration begins June 2020) |
12-28-2005, 05:28 PM | #3 |
Saving 1 truck at a time!
Cool old school unit. You can run the old style script valve covers since you have the oil filler tube there. It appears to be an older dual plane design so it will be best for a torque motor which will work best in these heavy trucks anyway.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
12-28-2005, 06:13 PM | #4 |
Yea. Since this purchase the engine plans have now changed. I was planning to build something a little lopey and strong but not too high pro and I'm still not going to go so far that it's not street driveable.
I'm maybe starting to get over my head with this but I've been there before. Just got to dig my way out. The trucks going to be a hotrod that's driven occasionally but not everyday. Thanks for the input.
12-29-2005, 11:53 AM | #5 |
Anymore advice?
JKR
12-29-2005, 12:55 PM | #6 |
67-72 Addict!
Are you planning to run HEI?. If so, I'm not sure the C3b intakes work with stock GM HEI distributors. My buddy had one 10 years ago.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-29-2005, 12:58 PM | #7 |
More Cowbell....
That looks pretty sharp. So...where is the rest of the truck????
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
12-29-2005, 01:33 PM | #8 | |
HEI it is but stock or not is a good question. Are you saying no HEI or just not the stock HEI? If not stock then probably I would chose MSD, that's what I'm considering anyway. JKR
12-29-2005, 01:34 PM | #9 |
PROJECT 7DEUCE
Hurry up and get that thing together lets see some burn out pics..... Congrats on the score..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-29-2005, 01:34 PM | #10 | |
Rest of the truck is in pieces. I've got an orginal pic somewhere. Let me look and see if I can find it. JKR
12-29-2005, 01:36 PM | #11 |
67-72 Addict!
If I remember a stock GM distributor will not work but don't hold me to that. I just seem to remember something about HEI's and those intakes.
12-29-2005, 02:34 PM | #12 |
Not here at work. I have some at home. Be prepared...it's pretty ruff!
