Old 12-29-2005, 02:48 PM   #1
Wootdog
Wootdog's Avatar
Door Rubbers
Anyone had a problem with the back of the door not closing after you install the rubbers? When I have them installed fat side out, the rear of the door will not be flush. I even removed the striker plate with the same results. It looks like the rubber gasket is too fat on the front side near the hinge area. When I install them narrow side out, the doors are flush but you can see daylight all the way around the door. I measured the thickness side to side and it is approximately an inch thick. My other set in the other truck are only 7/8". Could I have bought the rubber weatherstrip in the wrong thickness? Thanks, Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 12-29-2005, 02:52 PM   #2
Putter
More Cowbell....
Putter's Avatar
Re: Door Rubbers
Not that it matters, but did you get the glue-on ones (like original) or the S-10 style that more-or-less press on?
I just put my S-10 ones on yesterday and have the same problem. Basically have to use both hands and one leg to close the door from the outside. There is NO WAY it will close from the inside without ripping the handle off.
I am just hoping it will compress like the originals did.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-29-2005, 02:56 PM   #3
Wootdog
Wootdog's Avatar
Re: Door Rubbers
These are supposed to be the original type but the thickness is wider than what I have on my other truck. Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-29-2005, 03:00 PM   #4
Putter
More Cowbell....
Putter's Avatar
Re: Door Rubbers
On my original cab with original seals, at the front, those thing were compressed down to about 1/8" thick. I say just slam it and hope for the best. They have got to compress sooner or later.
Did you get those from a reputable vendor?
Old 12-29-2005, 03:04 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: Door Rubbers
Original style or S-10 style will do this for several months. It's normal even though it's a pain. Another trick that helps is to poke holes around the rubber with an awl every 4". I got that from Bill Athey!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-29-2005, 03:07 PM   #6
Wootdog
Wootdog's Avatar
Re: Door Rubbers
The problem is the back of the doors sticks out even though the door is against the striker plate in the back. They shut just sitck out and it is bothersome. Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-29-2005, 03:09 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Re: Door Rubbers
I hear ya Kerry. I would let it go until spring before adjusting the striker.
Jim
