Old 09-12-2002, 06:27 PM   #1
useRc10
useRc10's Avatar
vortec heads q?
will the vortec heads off of a new truck work on my 350? I see lots of them off of teh new 5.3 Ls and was wondering if tehy will fit...
thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 09-12-2002, 08:17 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
Nope - the Vortecs in the new style of trucks (the Silverado bodystyle, 1998 and newer) are a completely different engine. The 4.8, 5.3, and 6.0 V8's are all based off of the LS1/LS6 found in the 1997 and newer Corvettes, and 1998-2002 F-Bodies. Completely different block, not even close.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 09-12-2002, 08:27 PM   #3
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
but the ones off of Vortec 5.7s from the pre-99 trucks will fit, but require a new intake manifold... or drill/tap the heads...
good design... almost as good as an LT1...
1968 GMC 910 Long Step 250/3onTree
1969 Chevy C10 longfleet, 350/350
68_GMC_910 is offline   Reply With Quote
Old 09-12-2002, 08:51 PM   #4
Project1970
14.1 @ 96MPH
Yup, I've got them on my truck. They rock hard, heh. You can't put LT1 heads on a GenI block, though (reverse coolant flow) and they outflow the far more expensive aluminum L98 heads if you want to stick all GM.
Old 09-12-2002, 09:10 PM   #5
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
yeah, I know... if the LT1 heads would fit I'd be out right now prying them off of a Camaro... *lol*
oh, I should have mentioned valve covers... you'll need center bolt valve covers with Vortec heads, I think...
Old 09-12-2002, 09:15 PM   #6
Project1970
14.1 @ 96MPH
Yep, you'll need centerbolt valvecovers (which are much better than the original ones imo) and you also can't use the factory A/C bracket that goes to the intake manifold.
I still haven't figured out how I'm going to mount the A/C once I get headers, though. Right now, it's mostly on the exhaust manifold mount.
Old 09-12-2002, 10:12 PM   #7
nate68
alan grove has the a/c brackets that work with vortec heads
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-12-2002, 10:29 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget guided rockers...you'll need them too.
Old 09-13-2002, 09:00 AM   #9
Woody
nate68,
Hey got any more info on the a/c brackets from alan grove?
Price? Work with stock compressors? Pics?
Woody is offline   Reply With Quote
Old 09-13-2002, 09:30 AM   #10
deadmeat521
also if you want a big cam go with lt4 valve springs the stock can go up to .450 lift and you do need a n intake for them and i love my vortecs
72 pickup:vortec heads,msd ignition,& m22 rock crusher
deadmeat521 is offline   Reply With Quote
Old 09-13-2002, 02:41 PM   #11
Project1970
14.1 @ 96MPH
...LT4 valvesprings fit? That's probably a lot cheaper than getting the heads machined for stock-size springs, too...
Old 09-13-2002, 04:48 PM   #12
deadmeat521
no they do have to be machined but you get a set with the springs already installed from sdpc2000.com
Old 09-13-2002, 10:01 PM   #13
Project1970
14.1 @ 96MPH
Eh? Is it an option or do they do it to all of them? I got my Vortec head kit from SDPC...great deal, I should add...I know I didn't specify any stronger springs, so my guess is I don't...but that's cool that LT4 ones fit!
Old 09-13-2002, 10:07 PM   #14
deadmeat521
thats what pissed me off they started offering the upgrade a week after i got mine and yes they still offer it for 900 or just the springs for 250 i think. they also offer upgraded heads and edlbrock air gap intake for a little over 1000
Old 09-14-2002, 08:44 PM   #15
nate68
www.alangrovecomponents.com
i'm running a sanden compressor (cuz the A6 stock ones suck and they drag down your motor bad) on the driver's side. they make em for both sides. they come with all the spacers n stuff
