Old 12-26-2005, 11:09 PM   #1
Striker169
Car O'Holic
Striker169's Avatar
Eexhaust With Underbed tank?
How is everyone running their exhaust with a under bed tank?
Striker169 is offline   Reply With Quote
Old 12-27-2005, 12:10 AM   #2
rkarr
rkarr's Avatar
Re: Eexhaust With Underbed tank?
I was thinking I'd route out before the rear tires... Or better still, I'd blast a hole in the bed and exit with a chrome ring around the exhaust tip...
Who has pics of headers for these 67-72's? I'm looking for good headers for a small block that don't drop below the frame...
~Russ
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 12-27-2005, 12:31 AM   #3
QKENUF4U
QKENUF4U's Avatar
i have mine over the axle with a blazer tank conversion. works perfectly fine. just wish i had flowmasters on it instead of the dynomax (?) mufflers. it dumps right as it comes over the rear end. looks fine and works perfect.
QKENUF4U is offline   Reply With Quote
Old 12-27-2005, 12:44 AM   #4
prerunner68
prerunner68's Avatar
My exhaust stops just behind the cab and the fuel cell is behind 9" rear end.
The skid plate in the avatar hold the cell in.
Now why, Would you cut up a 68 to go play in the desert with??
prerunner68 is offline   Reply With Quote
Old 12-27-2005, 12:52 AM   #5
subtle71
Granddad's Ol' Truck
subtle71's Avatar
Exhaust with the under bed tank should not be a problem. Here is a shot of mine, sorry it is not the best. The pipe loops up over the rear axle then flares towards the outside of the truck just in front of the tank. This shot only shows the driver's side but gives you an idea. Hope this helps.
Dean
1971 Chevrolet Custom 10 short step-side
2005 GMC Sierra SLT 2500HD crew cab 2wd
[I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side
subtle71 is offline   Reply With Quote
Old 12-27-2005, 02:54 AM   #6
Striker169
Car O'Holic
Striker169's Avatar
that does help.. hmm I just gotta figure out how I want to go about doing this....
Old 12-27-2005, 07:12 AM   #7
The same as I would on a Blazer or Suburban.Heat should not be a problem as long as you have air-space.
Old 12-27-2005, 08:48 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mine turns out in front of the rear tires, of course it's a blazer and not a
truck, but you get the idea, lots of pic's in my siggy link, pages 14-16 ?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-27-2005, 10:02 AM   #9
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
I don't have pics of it but I saw a system that went through the frame rails. The owner boxed the frame in about a 8" section and then welding a 4" section of pipe at a 45 degree angle. Then he was able to run the exhaust out side the frame rails without going under them. Sounded really good.
I have the exhaust running out before the rear tires on mine at it is to loud in the cab for me. I like a loud exhast system and all I just want to be able to hear the radio too.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 12-27-2005, 10:25 AM   #10
matthufham
mine go parallel with the frame, and 90 out in front of the rear tires. keep in mind if you have the poly version of the blazer tank, keep the exhaust pipes 3 inches away, if you're running the steel version, use an inch or so (you should be able to slide your hand through the gap)
matthufham is offline   Reply With Quote
Old 12-27-2005, 11:53 AM   #11
modifiedGMC
I ran mine on the outside of the frame and then to the back. They turn out at a slight angle to the corners.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 12-27-2005, 12:02 PM   #12
Putter
More Cowbell....
Putter's Avatar
Here is how I have mine. Before and after the roll pan.....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-27-2005, 07:53 PM   #13
And I like it.
Old 12-27-2005, 11:48 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
Didn't want to see the exhaust so it was up over the rear axle turned down about 3/4" from the bottom edge of the beside and about 1/2" below the bottom edge of the bedside. Leonard's on South 1st Street did it and did a very nice job....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 12-28-2005, 10:46 PM   #15
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Eexhaust With Underbed tank?
heres mine.
need to get under there and repaint it i guess.
Old 12-28-2005, 11:05 PM   #16
kaycee
kaycee's Avatar
Here's mine
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-28-2005, 11:22 PM   #17
matthufham
@QKENUF4U
you should turn those down, water will collect right there, and the fumes get stuck under the bed that way
Old 12-28-2005, 11:30 PM   #18
matthufham
rick, that's the poly version of the blazer tank conversion kit. it comes in steel and poly, i have the poly one from gmcpauls.
Old 12-29-2005, 11:30 PM   #19
70c10swb
no brain no headache
70c10swb's Avatar
Originally Posted by kaycee
Here's mine
Perfect!
any pics from under?
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 12-30-2005, 12:14 AM   #20
kaycee
kaycee's Avatar
Cool Re: Eexhaust With Underbed tank?
No pics from under side let me see if I can get some tomarrow ,and thank you for the compliment
2005 FXDWG stage3
63 IMPALA 327
