#16876
Front bumper help needed
I removed the front bumper before the truck went to the body shop. After it came back, the bumper dont line up right. I'm at a loss as to why. I do not see where anything chould have changed. Its good on one side, but the other side is low & in (see pic). Anyone know whats going on, or how to fix it?
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
I'm watching you!
Re: Front bumper help needed
Did you have the bumper somewhere it could have been bent while off the truck? Or did the body shop somehow bend the bumper brackets?
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
Did you remove the brackets or just the bumper? Either way it sounds like the bracket needs adjustment. You can get a lot of leverage on the bracket to move it around. Also some of the holes are slotted.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 01-02-2006 at 12:26 PM. |
#16876
No. Not that I can see. The holes on the brackets still line up fine. One thing I considered is that the fender could be out of whack. They took that off in order to slavage the emblems. The body is straight, and lined up. So I have sort of ruled that out too.
#5 | |
#16876
![]() Join Date: Jul 2004
Measure from a fender tip underneath to the frame, then center radiator support on frame. Shim radiator support as needed to get level with bumper. Shim bumper at front to get distance between grill and bumper equal. Even if they did not have support loose, it still may need to be centered.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
