Shaving antenna, where to put it?
I have my cowl off the truck right now, along with every other body panel, and before I repaint it, I think I want to shave the antenna. I always thought it looked kind of goofy up there, and my stock antenna is thrashed, so moving it is the obvious answer. How hard is it to fill in the hole, and where does everyone usually relocate an antenna to? I will be buying a new one, just not sure which new one. Any suggestions? Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
A guy with a truck
Re: Shaving antenna, where to put it?
Just a little sheet metal welding... no big deal. You may have to contour the plug you make a little for a smooth fit. There are stockers with no hole but may be hard to find.
The Harley guys have powered antennas for the full-dress bikes. Its a little black box you can hide anywhere. You could also just put the stock mast behind the dash. Should be OK around town, not so good on road trips...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Questionable
Where to move it? Where the gas cap used to be
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() Join Date: Aug 2005
I shaved mine and just temporarily put the antenna under the dash an I get great resception.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
The gas cap is actually still there shifty, but I thought about frenching it into the passenger side. I'd move my tank, but I got rear ended by an import sedan and it ended up right where the blazer tank would have been. I really like the look of that autoloc one though, completely hidden, and if it gets good reception, that's all that matters to me. It says no AM, but I can't think of a time I've ever listened to AM (except in the truck, because it was better than the sound of wind).
Keep On Truckin'
Here's the Autoloc antenna on Ebay for about the best price. I put one in my truck and it gets good reception although I haven't been out of town with it yet.
http://cgi.ebay.com/ebaymotors/AUTOL...spagenameZWDVW
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 01-06-2006 at 08:12 AM. |
its all about the +6 inches
I have mounted them under the cowl, and never had a problem at all.
pick a good cam a set of carbs and exhaust!!! removes the need for artifical noise
Put it under the carpet--works fine.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Not to jack the thread, but I have a radio delete cowl, but some dumb @ss drilled a flippin' hole in it!! It is not nearly as big, but what a dumb@ss!!
Vintage Evil
I have one similar to the auto lock that i bought at advanced auto parts. It is not totally hidden. I mounted in between the mirror and the headliner. It does a pretty good job.
Mine is under the passengers feet. It works oky to get local stations. Never mind it was $4.99 at walmart.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#14 | |
#15 |
Nope it about 14" long plastic one. It's under the carpet and padding. Nobody ever notice it there.
