Old 09-14-2002, 07:09 PM   #1
72MARIO
72MARIO's Avatar
Very Important info for you Guys wishing to run 73 and up Spindles
Here I go this took myself and Bill the owner of Bills truck shop in Ontario Canada to figure out Thought I would pass it on to you guys !Here is the list of stuff you need to Know .
1. The center link from 67-70 is diffirent from 71-72 the holes are bigger in 71-71 than in 67-70 YOU need to use a 67-70 center link or the one with the smaller holes .
2. Use 73 -up outer tie rod .
3. Classic Performance Products sell the sleve you must use it has 11/16LH thread on one side and 5/8 RH thread on the other. part number CP4SC $49.00 Bill can also get you the stuff just give him a call.
4. you must use a 67-70 outer tie rod on the inside seriously !
5. If you are thinking well the inner tie rod should be long /The sleeve in a quite a bit longer than the original.
6 you also use 73 up ball joints(not sure if you have too)
Bill can get you the part 's also he is a guy a runs a awesome shop. his number is 905 725 3460
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-15-2002, 12:46 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
i dont know how or why but some of the 71 72 trucks have same center link as the 64-70 trucks(except with ram linkage p/s basically) i have seen both large hole links and small hole links on 71 72 trucks, differenc emay be if with p/s or not
71 72 lower ball joints are same as 73-87 ones, and uppers changed in 71 and yet again in 73
you also need 73-up hoses or at least year of hoses for the year calipeors you are using because 73-up hoses pass through the framwe rails and 71 72 pass under frame rails and are tons shorter hoses. i prefer the 73-up style alot more and holes for thme already exist in our frames.
happy swapping
Fast68Chevy is offline   Reply With Quote
Old 10-02-2002, 10:19 PM   #3
Spoof
Spoof's Avatar
I need to re-check this but it appeared to me that the 73 outer tie rod end I have fit the 71 sleeve perfectly, threaded on just fine when I was doing a pre-assembly for my drop spindles. I'll check again, but I hope I don't have to order the custom sleeves!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 10-03-2002, 12:18 PM   #4
LowSeventy
Why go through all this trouble swapping everything out? Early Classic manufactures a drop spindle for the 1960-70 trucks that bolts right on. I bought their kit and it bolted directly onto my stock 70 front end. My cousin and I installed the entire disc brake 4/6 drop kit in my driveway on a Saturday, with virtually no trouble at all. We had just a couple questions and they were so cool on the phone and helped us out. I would recommend their stuff to anyone.
LowSeventy is offline   Reply With Quote
Old 10-03-2002, 05:24 PM   #5
Spoof
Spoof's Avatar
I thought that's what I WAS doing when I ordered my Belltech drop spindles. I made every effort to ensure they were year specific and would bolt right in, two phone calls to confirm and still the spindles for 67-72 trucks require a 73 tie-rod end, in spite of them repeatedly telling me no mods would be needed. GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!
71 GMC 1500 LWB
Old 10-03-2002, 06:26 PM   #6
LowSeventy
Wow, that sucks! I thought Belltech had their act together, but I guess not. Did they tell you can't run a stock wheel with their 3" spindle? That's another reason I went the ECE, I can use my stock rally wheels with their 2.5" spindles til my 17"s get here.
Old 12-21-2002, 12:14 AM   #7
72MARIO
72MARIO's Avatar
ttt
2005 TAHOE DD
Old 12-21-2002, 06:17 AM   #8
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I believe all the manufacturers stopped making the 3" drop spindle years ago because of clearance problems on some rims. I haven't seen a 3" spindle advertised in quite some time. I could be wrong, it happens.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 12-24-2002, 02:41 AM   #9
69c10stepside
Large Member
69c10stepside's Avatar
summit still sells 73-87 chevy 3"drop spindles.. if you have the recent mini-catalog its on page 125 djm's
1989 GMC C1500 ECSB
1972 Gmc Jimmy
1972 Chevy C10 SWB Sold
69c10stepside is offline   Reply With Quote
Old 12-24-2002, 03:46 AM   #10
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Those chevy 3" drop spindles, for how much do they run? I don't have the summit catalog
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 12-24-2002, 12:35 PM   #11
69c10stepside
Large Member
$225.95 part number is djm-ds2045h-3
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 12-29-2002, 05:13 PM   #12
70 Jimmy
70 Jimmy's Avatar
I paid $240 for my 72 2.5" drop spindles from Early Classics. For a few dollars more, you get great service, and you can use all stock components, including rims.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 12-29-2002, 07:55 PM   #13
chevy_fatman
Where's my beer?
Hey 70 Jimmy, did you also get lowered springs?, if so, how low did you go? I'd like to see some pics of your ride if you had any
Paul
Old 12-30-2002, 12:49 PM   #14
70 Jimmy
70 Jimmy's Avatar
Unfortunately, it's "how low will I be going". Still not done. I've got 3" drop springs for now, but plan on bags. That with 2.5" spindles and a 1.5" notch, it'll be 7" up front and probably 9" at the rear. I'll see how that looks and how practical it is around town. It's a short wheel base, so I should be fine. I'll post pics when the engine is in.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 12-30-2002, 03:18 PM   #15
chevy_fatman
Where's my beer?
Well keep us posted, I like to see some progress, even though the progress is not in my truck
Paul
Old 12-30-2002, 08:57 PM   #16
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
price i think there kit is like, 6-700 something??? thats a little pricey for me
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 01-16-2003, 10:43 PM   #17
truckman32
AND HOLDING ON TO THE C10
truckman32's Avatar
Post swaping spindles
i have heard alot about swaping spindles for disc brakes on 62-69 and i have researched alot info on it at stovebolt and i think the best way to do this is just swap the complete front crossmember IFS.actually i had a 81 1/2 ton scottsdale ifs under a 66 bare frame and the fitment was okay except drilling two holes on the frame.and the brake lines fittins were metric but there are adapters so not a problem but thats as far as i got i hade to move and couldn't take it with me,so this time i'm going with a 72 IFS on my 66 since i'm doing a total frame off restore.anybody else got any info on the ifs swap
ther is something women like about a pickup man THE BED
1966 c10 short wheel base stepside bowtie:
1985 s10
1986 f==d
1994 dodge intrepid
truckman32 is offline   Reply With Quote
