easy ?
hey how does the light switch knob come off? i see a set screw on the wiper switch but not on light switch i pulled on it pretty hard but dont want to break the switch
common sense isn't so common anymore |
No,I DON'T have Tourett's
Re: easy ?
Reach up behind the dash and press a release on the top of the switch.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
Old Skool Club
![]() Join Date: Jun 2001
Re: easy ?
There is a release for the knob/shaft ass'y, located on top of the switch ass'y. When you press on it, you can pull the knob/shaft out of the switch. Then, you can unscrew the "nut" on the front of the switch and remove it from the dash......also, you gotta unplug the connector that fits on the switch. I'd strongly recommend disconnecting the battery (positive cable) before reaching up under and behind the dash.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: easy ?
thanks guys
![]() Join Date: Sep 2005
Re: easy ?
should be an reasle button on the top of the stiwch knob shaft and all pull right out but like chevy said unhoook the battery
![]() ![]() Join Date: Jan 2005
Re: easy ?
Pull the knob out as far is it will go FIRST. Then press and hold the release button and pull the knob the rest of the way out.
Re: easy ?
I think there's a release button on top of the switch....
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey**** 68' C10 Short Step (rebuilding as we speak) 72' Custom Camper (wrecked, parting out) 79' C10 Fleet (rough, parting out) 97' C1500 Short Step Custom (DD) 97' Kawaski VN800a Customized 99' Z71 Silverado 04' Suzuki Volusia |
#8 | |
Son Of Gravel Man
Re: easy ?
I never had to use the release button on mine. Just kinda did a counter clockwise twist and pull. Is mine broke?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
its all about the +6 inches
Re: easy ?
only if it came out without pressing this little button on the top of the switch.
#10 | ||
Son Of Gravel Man
Re: easy ?
Re: easy ?
Re: easy ?
Unplug the battery because pulling the knob out also turns the lights on.
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: easy ?
A pic to go with this thread,thanks to who ever shot this.
