Old 01-10-2006, 01:02 PM   #1
Deuce
Deuce's Avatar
Will 73+ Ball Joints Fit in 67-70 Control Arms??
I don't want to do a crossmember swap and the truck has 3" drop tubular control arms so I want to keep them if I can.
Has anybody actually installed these ball joints in a 67-70??
Thanks.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 01-10-2006, 01:08 PM   #2
raggedjim
raggedjim's Avatar
Re: Will 73+ Ball Joints Fit in 67-70 Control Arms??
I have, both upper and lower, piece of cake...
Not sure about the tubular control arms but they will work with the oem's.
Watch the turning radius with the earlier lower control arm, the disc spindle will hit earlier than the drum. Also, if you use a 73 up spindle the tierod end is different...
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 01-10-2006, 03:27 PM   #3
Longstep70
Junior Member
Is it just the tie rod end that is different? If you go with 73+ components do you need the center link, idler, pitman etc??
Longstep70 is offline   Reply With Quote
Old 01-10-2006, 03:48 PM   #4
Deuce
Deuce's Avatar
Thanks. That was my next question.
I know you can buy a conversion adjusting sleeve from CPP to use the 73+ outer tierod and still keep the 67-70 steering components. I think its about $25. I think this is the route I'm going to go.
Thanks for the reply.
Old 01-11-2006, 05:53 PM   #5
raggedjim
raggedjim's Avatar
Guys, I used the centerlink, etc from a '72 with a '73 tierod end (so I could use '73 up drop spindles). Deuce is right about the CPP sleeve, I used a similiar one on a '64 chevy once and it worked well.
There's about a 100 different ways to do this, so have fun... I think you'll have to address the brake lines too, I'm thinking I had to change some stuff around on those...
Rg
Old 01-11-2006, 06:10 PM   #6
Deuce
Deuce's Avatar
Thanks Roger.
If I remember it disc brake lines are routed different and require a bracket welded on to support the brake lines??
Old 01-11-2006, 08:10 PM   #7
SCOTI
SCOTI's Avatar
I used the 71~72 center-link on my 67 (w/73 & up BJ.s) & I used a 73 & up center-link on my 68 (again w/73 & up BJ's).
Both trucks used the same non-power pitman arm & idler which is the same P/N for a 73~78.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2006, 01:43 PM   #8
raggedjim
raggedjim's Avatar
Deuce, they are routed differently, but the fittings are also different.
Here's an old thread that talks about it.
http://67-72chevytrucks.com/vboard/s...light=chevette
Good luck, Rg
