Old 01-12-2006, 01:35 PM   #1
Army_Dude
Question Speedometer calibration/adjustment...
I was lucky enough to score a used speedo from a board member after I broke mine. I got it in last night and when I drove it today I notice it is WAY off. It jumps up to about 20 mph almost instantly and it reads 70 to 75 mph when going down a road I know I travel 50 mph at best. Is there a way to adjust/calibrate or do you just live with what ya got? OR>>>>Is it possible I did something wrong on the install, it seemed pretty straightforward but hey I had to ask (ya never know). Thanks!
Army_Dude is offline   Reply With Quote
Old 01-13-2006, 12:20 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Speedometer calibration/adjustment...
As far as I know, the speedometers are all calibrated the same (indicated mph per 1000 rpm of the cable...), and adjustments are made with the speedo gear at the transmission. I believe they are even standardized industry-wide.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-13-2006, 01:46 AM   #3
Army_Dude
HHmmmm, I doubt that is in the haynes. Gotta go look
Old 01-13-2006, 02:56 AM   #4
hotrodhomi
hotrodhomi's Avatar
you need a new speedo gear in your tranny. they are about 5 bucks at the dealer. Cheap. you will need to know rear end ratio. tire size. tranny type, your mother favorite pizza topping.. the usual. good luck. They also have guys that specialize in speedo calibrations. They run your truck on a dyno type machine and make adjustments form there. Cost unknown.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-13-2006, 04:35 AM   #5
jimfulco
Did your old one read right? If it did, the new one should read the same, unless you changed something else (transmissions, speedo gears, or rear end gears).
Maybe it's related to the one in my '79. At a steady 75mph on cruise, I've seen it read anywhere between 60 and 95mph, and holding steady at those speeds, at least for a few minutes. Sometimes if you hit a bump just right it will jump to some other speed for a while. I thought about buying a used one, but I figured I already had a used one.
jimfulco is offline   Reply With Quote
Old 01-13-2006, 10:57 AM   #6
Army_Dude
Same as before
Yeah, the other one worked ok. So I know it has to be the speedo. I'm going to check my connection. Thanks.
Old 01-13-2006, 11:47 AM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The speedo in the head units are all the same. As indicated above the correction is made in the transmission with the proper gears.
It is basically done like this:
http://www.73-87.com/7387garage/drivetrain/spdgears.htm
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-13-2006, 12:11 PM   #8
Slonaker
Slonaker's Avatar
When I got a new gear for my speedo cable a couple of years ago (it had a burr, was chewing up the seals and leaking at the bullet), the shop told me that the gears are color coded. Mine was a kind of grayish-purple color. They got me one the same color, and it had the right number of teeth. That might help if you try to get another one. BTW, it was only a dollar or two at a place that provided transmission parts to local rebuilders.
Slonaker
Stock '01 Silverado
Old 01-13-2006, 01:36 PM   #9
Army_Dude
but what I'm not getting is how could it be the gear at the transmission side?All I did was pull my speedo, broke it while pulling it, and replaced it with another.
Old 01-13-2006, 02:04 PM   #10
greg0380
probably not the gear. let me know if you need a speedo, i have a couple from 85-86 trucks (85mph)
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 01-13-2006, 04:52 PM   #11
hotrodhomi
hotrodhomi's Avatar
does the new speedo have the same span?
'66 impala ht
Old 01-13-2006, 08:31 PM   #12
gearhead49
I doubt it is the tranny gears, I had a simular problem with mine. Ya might try taking the one part you need out of the new unit and putting it in the old one !
gearhead49 is offline   Reply With Quote
Old 01-13-2006, 09:01 PM   #13
hotrodhomi
hotrodhomi's Avatar
Could you elaborate?
'66 impala ht
