Old 01-12-2006, 02:04 AM   #1
domino52761
domino52761's Avatar
Unhappy 6 to five
doing frame up on 65 sort bed fleet side. realy like too keep stock rear end . what 5 lug axles will slide in . also will 92 s10 booster master and pp valve work . have all ready got 85 c 10 front disc parts/power steer gear box and pump 85 alt 327 sagonow 4 speed and s-10 stuff ho and what tilt colum will work s10 or no
russ
65 short box fleet side
94 s-10 blazer
88 chevy bretta gt
my sons a train nut
domino52761 is offline   Reply With Quote
Old 01-12-2006, 08:16 AM   #2
Bowtie67
Bowtie67's Avatar
Re: 6 to five
Here is probally the cheapest solution
http://www.classicperform.com/Store/...ruck/CP4R5.htm
http://www.classicperform.com/6092ch...20Brake%20Kits
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 01-12-2006, 10:32 PM   #3
qksilver
Re: 6 to five
The other option would be new axles with the 5x5 bolt pattern. One of my trucks that I am using the parts off of, the PO said he put 70 5 lug axles in the 65 housing. He said 70 disc only had the narrower rear with 5 lug. I looked at it and the axles don't stick out like when I tried 71 and up 5 lug axles in my 65 Burb. Again that's what he said so I don't know for sure but the work fine in my 65 swb, Except for the bent frame I discovered today!
Steve
qksilver is offline   Reply With Quote
Old 01-13-2006, 01:18 AM   #4
domino52761
Re: 6 to five
thanks for the imfo steve i have afriend that should have a 70sorry too hear about what you fond out to day my truck just about striped and ready to start sand blasting
russ
94 s-10 blazer
88 chevy bretta gt
my sons a train nut
Old 01-13-2006, 12:25 PM   #5
72MARIO
72MARIO's Avatar
Re: 6 to five
70's were 6 bolt. 71 up were disk.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-13-2006, 02:00 PM   #6
smbrouss70
smbrouss70's Avatar
Re: 6 to five
Any competent machine shop should be able to take your original 6-lug axles, weld up the holes and redrill them for the 5-lug pattern. Should cost less than $100 depending on your area.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-13-2006, 02:50 PM   #7
domino52761
Re: 6 to five
I have a 220 ark welder. I should bee able to weld in holes and take a 5 on 5 axel and vise grip them to gether and redrill my 65 axels for 0$ you think it work . I like to tinker any way. OR should i not chanse fing it up
russ
94 s-10 blazer
88 chevy bretta gt
my sons a train nut
Old 01-13-2006, 02:52 PM   #8
dennislbrooks
dennislbrooks's Avatar
Re: 6 to five
agree with smbrouss70 ----but don't bother welding the holes. center 5 so that it only interferes with 1 of the 6 holes and only weld at that spot. The weld is hard to machine and gains little. Flanges have to be turned down for the smaller drum center.
dennislbrooks is offline   Reply With Quote
