Old 01-13-2006, 01:18 PM   #1
fade94
fade94's Avatar
5 lug bolt pattern?
Is it 5x5? (71 Chevy 1/2)
I am looking for wheels and they are also listing a 5x5.5
I measured mine from outside of one lug to center of lug as close to straight across from it as possible, and it measured 5.5
Just need to know what is correct.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 01-13-2006, 01:20 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 5 lug bolt pattern?
5 on 5 is correct for the 5 lug trucks
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-13-2006, 03:28 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
A little reference material.
http://www.mrt-wheels.com/boltpatternref.html
sneakysnake is offline   Reply With Quote
Old 01-13-2006, 04:09 PM   #4
70rs/ss
70rs/ss's Avatar
Truck and big car (Chevy) have the 5 on 5. Caprices, S-10,etc if you are just looking for wheels that fit instead of just buying wheels.
70rs/ss is offline   Reply With Quote
Old 01-13-2006, 04:18 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
s-10's were 4 3/4
Build Thread
Old 01-13-2006, 05:15 PM   #6
fade94
fade94's Avatar
Right now I have some funky factory GM, later model wheels...
Will be tearing apart my motor that will go in the truck today. Building it pretty stout. Looking at a Rallye for it, 15x10 rear 15x8 front, or an aluminum Drag Lite type wheel, same size. Just wanted to make sure I had the correct info for the bolt pattern.
Old 01-13-2006, 05:15 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
So were many Caprices.
Old 01-13-2006, 07:55 PM   #8
bighead
Give me a shout if you need a hand with the motor.
bighead is offline   Reply With Quote
Old 01-14-2006, 09:51 AM   #9
fade94
fade94's Avatar
Change of plans. My son called and his truck is acting up. So, I'll be jacking with it at least today. May go ahead and put that cam kit in my motor and drop it in his truck. May be easier than trying to diagnose what's up with his. Died on him once going down the highway, wouldn't start at school, waited an hour then it fired up. Thinking either a fuel issue, or coil issue. Already has an oil pressure issue, so I think I'm just going to put a motor in I'm confident in.
