Quality of repop 67-8 Radiator Supports
Ok, so I got my frint clip disassembled to be blasted.
The radiator support has the rot in the usual places. Do I got for a re-pop or repair what I have. If you have a repop, what did it take to get it to work? What brand did you buy? |
Re: Quality of repop 67-8 Radiator Supports
I don't know the extent of the rot but I saw on GMC Paul's (IIR) a core support patch panel for the rot under the battery box. I think it was Paul's that had it. Unless the core is tweaked from a wreck, this looked like a good option.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I looked around, couldn't find it.
Have a link? Thanks much, this made my day! |
i have a good one ill sell you for $20, no rust anywhere on it, its really good.
my radiator supports a gmc, i just realised. got two lights on each side. sorry!
Found it on Brother's site:
http://www.brothersonlinestore.com/p...number=RSP72RH Looks about perfect for what I need to do: ![]() Too bad it's not for a 67-8 ![]() Last edited by FormerMember; 01-14-2006 at 11:56 PM. |
![]() Join Date: Jun 2002
Grendel, I think the only difference is it won't have the bolt holes for the front apron that goes on a 67-68... If that's the case you could weld it in and then drill holes in it where needed for to use bolts with nuts to attach the apron.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
