Old 01-14-2006, 05:33 PM   #1
matthufham
73-87 engine mounts
Whoops, I threw away my 72 mounts instead of the 77s it looks like, so right now for my 72 I’m attempting to line up the pair from the 77. The top mounts line up on the frame rails, and the bottom holes don't line up for the cross member mount. I can drill some holes in the cross member and be done with it right? They’re a 1/2 closer together than they should be but there's plenty of tolerance for that. Also isn’t there a benefit to using later model mounts?
matthufham is offline   Reply With Quote
Old 01-14-2006, 05:56 PM   #2
ratrod67
ratrod67's Avatar
Re: 73-87 engine mounts
Are you installing a small block? If so I have a set you can have. I'm in Ft Worth.
ratrod67 is offline   Reply With Quote
Old 01-14-2006, 08:22 PM   #3
67chevemall
67chevemall's Avatar
Well dam your hooked up just like that.....
lov this site
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-14-2006, 08:48 PM   #4
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Well the mounts are really not that different. If I remember right the 73-87 style mount will move the motor back to the firewall about a inch. Other then that its cool.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 01-14-2006, 09:39 PM   #5
matthufham
well i hope i don't have firewall issues, the hei looked hard pressed already. i had mounts for a smallblock for both the 72 and 77 so the motor will bolt in no problem.
edit:pics, i think i got an inch to spare, will i need a bigger fan spacer?
Old 01-14-2006, 09:52 PM   #6
That is what I had to redo today. Mine uses the later style mounts. I swapped out the front end on mine and had to redrill the holes in the crossmember. There is something about this in the FAQ area. Supposedly the newer mounts are much stronger and easier to slip an engine onto. My opinion, go with the newer ones since you have them.
BTW - I have HEI and there is plenty of room between the firewall and distributor.
Old 01-14-2006, 10:13 PM   #7
matthufham
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
