TOTY 2006
![]() Join Date: Dec 1999
Where do I find spring for auto column shift???
Hi All,
On automatic trannys that are column shift, there is a spring that slides onto the c-bracket that is bolted to the tranny (and it holds the floating bracket that the shift rod is connected), where in the hell can you get that spring brand new??? UDATE I found one on my spare tranny, but when I use that tranny I still need to find these. Will try Napa (the shops around here, the guy behind the counter just gives me a blank stare....) John Last edited by John Fabris; 01-14-2006 at 10:56 PM. |
An American Soldier
![]() Join Date: Feb 2005
Re: Where do I find spring for auto column shift???
John, I don't think it is anything special. You can just measue the lenth and the diameter and go to NAPA and find a spring to work.
I have one in my tool box, if you are not in a hurry. I live at Fort Irwin, CA, but I am on temporary duty at Fort Gordon, GA til the end of the month. If you haven't found something by then, send me a message and I'll get it to you.
Dan dan.brue@us.army.mil |
What are you doing for exhaust ? If you going thru the crossmember You might be better off looking at the Lokar setup. I have it on mine and it works great.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
My local True Value Hardware has a spring assortment and I found one that works just fine on my th350, not exactly like the original though.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
