![]() Join Date: Aug 2005
Performer RPM ?
Is anybody out there running an RPM Intake and Cam combo? If so, how do you like it and how is the idle? Rough for street use?
Re: Performer RPM ?
Nobody's running this combo?
Re: Performer RPM ?
Guess not... alright, here's the specs on it. Anyone care to weigh in on it?
Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-6,500 RPM Intake Duration at 050 inch Lift: 234 Exhaust Duration at 050 inch Lift: 244 Duration at 050 inch Lift: 234 int./244 exh. Advertised Intake Duration: 308 Advertised Exhaust Duration: 318 Advertised Duration: 308 int./318 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: No Lifters Included: Yes Lifter Style: Hydraulic flat tappet |
Aluminum slot wheels rule...
Re: Performer RPM ?
ttt
WTB this ad
Re: Performer RPM ?
I personaly run the performer on both of my trucks. I just thought that they were more suited to the RPM range I would be running.
Re: Performer RPM ?
I have the RPM intake on my 355 with the 327/350 Hp cam. It works great.
Not sure on the cam in that kit. Just make sure you have the power in the range where you will be driving most of the time. It's no good it your making 375 hp at 6000 when you cruize at 2000 and make 150 hp in that range.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: Performer RPM ?
Well that was my concern since the performer's range is supposed to be idle to 5000 but I figured the rpm should be ok since its range starts at 1500 and even though I don't have a tach, I know i spend a lot more time at 1500 then i do at idle.
Re: Performer RPM ?
It's the cruize speed that matters you want the truck to have power starting around 800-1000 that way you have the bottom end power you most likely need.
Unless your using 4:11's and running in the 1/4 mile at 6500rpm, the Performer setup is better for the street. We all want to say we have a massive cam and 500 HP but at what RPM ? The key is getting the power in a range where it actually get's used. All I have is the intake on my motor the cam is mainly what controlls what rpm the power is made. Low end power is best for economy and driveability.
Re: Performer RPM ?
Good point Mario. The other thing I would be concerned about would be whether my 600cfm carb would be enough with that combo or would i need to bump up to a bigger carb.
Re: Performer RPM ?
500cfm is enough for a 400hp motor jetted correctly. A 600cfm will be fine. You can go bigger but it's not necessary. If you put in a huge cam (Which work great at high RPM that's what Race cars have them and sound that way)
You might need to increase the jet size.
Re: Performer RPM ?
Yeah this is true. Well I reconsidered on that RPM cam and I'm going to go with the milder Performer cam instead. Thanks for the good info!
Dork For Days
Re: Performer RPM ?
You didn't say what size engine this is for.
Either way those duration figures are a bit stout. Normally big block truck engines run about 220* of duration and the SBs a little less. The lobe separation isn't bad, however. I'd check out the Edelbrock dyno sheets for the different combos. Look carefully at the torque curves. You're going to want as much down low as possible with the flattest curve you can get. You could also plot the combos in Dyno 2000 or something similar to get a better idea.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! ![]() 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
Re: Performer RPM ?
The Edle cams are old school, go with a Comp Cam, Crane, Crower etc. the RPM cam unless you have some good CR it will run just OK, till I meet up with you at the light and leave you like you have an old Iron Duke 4CYL..
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
Re: Performer RPM ?
Please post your combo in detail here include your compression ratio.
Both edelbrock cams are crap in all honesty ill give a reason why. With the RPM you have 308/318 degrees of advertised duration. You really need at least 11:1 maybe 12:1 compression for that to work worth a hoot. Then the .050 duration is only 234/244. That is a TERRIBLY slow ramp and you would be leaving alot of power to be had. If you want me to explain this in serious detail i can. Call up a few major cam companies and get some responses on your combo. But i will guarentee you that youde be leaving TONS of torque and at least 20 hp and some gas mileage on the table by running an old ass Edelbrock cam. Call Crane, cam motion, erson, bullet, crower, howard, isky. Actually i would call Lunati about their new Voodoo cams. Harold Brookshire designed them so you know they are good. He used to own Ultrdyne cams and designed comps HE line 20 yeas ago. Call Lunati for sure....but DONT GET THE EDELBROCK CAMS....
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
#15 |
Re: Performer RPM ?
Alright here's the juice on the engine. Short block (010 casting), 350 bored over .60 with new speedpro pistons/xrods, new crank and a lunati cam. The problem is the guy I bought it from doesn't recall what lunati cam it is so I can't look up the specs and I'm pretty sure it's not a voodoo. This things been sitting too long for it to be a voodoo.
A guy I know's got a garage and we're gonna drop it in there but I won't know how the lunati's gonna be until the engine's built and in the truck. Unless somebody else knows where I can get numbers off of a lunati cam, I just don't trust it. |
#16 | |
Re: Performer RPM ?
Novaguy73: Harold Brookshire is no longer with Lunati.
#17 | |
Re: Performer RPM ?
#18 | |
Re: Performer RPM ?
Thanks bowtie, the engine's sitting in the bed of my pickup so I can pull it.
#19 |
Re: Performer RPM ?
Ok, I pulled the Lunati cam and here's the specs on it based on Summit:
Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-5,200 RPM Intake Duration at 050 inch Lift: 218 Exhaust Duration at 050 inch Lift: 218 Duration at 050 inch Lift: 218 int./218 exh. Advertised Intake Duration: 284 Advertised Exhaust Duration: 284 Advertised Duration: 284 int./284 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.458 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.458 Valve Lift with Factory Rocker Arm Ratio: 0.458 int./0.458 exh. lift Lobe Separation (degrees): 110 As a comparison, here's the Edelbrock specs again: Cam Style: Hydraulic flat tappet Basic Operating RPM Range: Idle-5,500 RPM Intake Duration at 050 inch Lift: 204 Exhaust Duration at 050 inch Lift: 214 Duration at 050 inch Lift: 204 int./214 exh. Advertised Intake Duration: 278 Advertised Exhaust Duration: 288 Advertised Duration: 278 int./288 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: No Lifters Included: Yes Lifter Style: Hydraulic flat tappet They both seem pretty tame. Which would you guys go with? |
#20 |
Fabricate till you "puke"
Re: Performer RPM ?
Forget about the edelbrock cam....let me say that again...FORGET ABOUT THAT EDELBROCK CAM! It is old school as allready posted. i have the complete EDEL package.....less the cam. the heads & intake rock. I run Edel rpm heads, intake, used the timing set......tryed the carb(didnt like it), it was not a Holley! My 383 runs an XE 268 comp, & it runs decent......I reccomend (on a 9.5 to 10 to 1 motor), the XE, or XS 268(solid), or an Isky solid, or lunati "voodoo" in the same range.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#21 |
Re: Performer RPM ?
Got it, no Edelbrock!
![]() How about the Lunati (non-Voodoo), worth a shot or should I look at the Voodoo. Keep in mind, I already have it since it came with the engine. |
#22 |
Re: Performer RPM ?
I would give it a shot,the specs dont sound bad on that Lunati cam , for a perf /driver. You can always upgrade later, if you want more....
#23 |
Re: Performer RPM ?
Thanks CrazyL!
#24 |
Re: Performer RPM ?
I also did not like there 1406 carb on my 84. I love my Demon it's like a holly but diffirent.
#25 |
![]() Join Date: Aug 2001
Re: Performer RPM ?
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
