Old 01-14-2006, 05:37 AM   #1
DroppedZ84
DroppedZ84's Avatar
Where to get new Junction Block?
The Junction Block that goes on the firewall...I'm going to do that headlight upgrade, and I want to put a new JB on too, because of the electric fan and stuff..where would I get one, and about how much can I expect? Thanks.
DroppedZ84 is offline   Reply With Quote
Old 01-14-2006, 04:05 PM   #2
1976K5CHALET
1976K5CHALET's Avatar
Re: Where to get new Junction Block?
I'd check around some of the aftermarket catalogs first. Or if you have a good contact at a gm dealership who will take the time to look something older up for you it might be still had thru gm. Since i worked at frieghtliner for 10 years i am going to use something similiar but its a bulhead connector as a hole has to be drilled thru the firewall as i want all my accessory circuits seperate from the oem fuse panel. I'm going to run 3 so i have batt hot - gnd - and ign.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 01-15-2006, 12:57 PM   #3
1976K5CHALET
Chevy duty....$2.99.
DW
Certified K5 Nut
Old 01-15-2006, 01:52 PM   #4
Russell
Professional Grade
Russell's Avatar
stock one has something like 12 spare ports in it. Just need to find a source for the crimpable spade connectors it uses...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-16-2006, 10:36 PM   #5
DroppedZ84
DroppedZ84's Avatar
You guys are thinking of the wrong part, I think...
This is the little diamond shape thing, on the top of the firewall, has two posts on it, one is BAT and the other goes somewhere into the truck...
Old 01-16-2006, 11:29 PM   #6
Russell
Professional Grade
Russell's Avatar
Junkyard 2 - 3 bucks
Old 01-17-2006, 12:44 PM   #7
DroppedZ84
DroppedZ84's Avatar
I knew that, but I want a NEW one...
Old 01-17-2006, 01:51 PM   #8
7T7
Regular guy
7T7's Avatar
Try MAD......
http://www.madelectrical.com/catalog/cn-1.shtml
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 01-17-2006, 05:33 PM   #9
DroppedZ84
DroppedZ84's Avatar
Originally Posted by 7T7
Thanks Frank! Exactly what I was looking for! I wonder if I can get that locally..maybe even at Home Depot/Lowe's...I need to rewire everything, for better power distribution anyway...
