Dual exhaust options for my 87 454?
I've got an 87 454 1 ton 4x4 GMC that's currently got what looks like a home-made, fully welded dual exhaust with no cats. The exhaust is dieing a very quick death, so by next fall I want to replace it. I'd like to run a dual exhaust just like I have now, except that I need to try and find a place to put cats in so that I can be all nice and legal. The thing is, it's very tight up there with the exhaust running next to the transmission and transfer case above the crossmember. I don't really know if I can accomplish what I want, or if I'm going to have to try and find a y-pipe and go back to a stock type configuration.
Anybody have any info/suggestions? |
Re: Dual exhaust options for my 87 454?
Get some aftermarket small cats and they should fit under there.
Support your local search and rescue team.... GET LOST! Originally Posted by DURRTY if some is good more is better too much ought to be enough........ |
No No
http://www.maremont.com/Default.aspx?pid=7
check this site out. You may have to use 86 since your truck is the odd ball crossbreed. ![]()
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
I noticed that LMC has a good amount of exhaust options, but they're only 2 1/4". I've got 2.5" now, although since my truck's motor is totally stock, 2 1/4" would be sufficient. Anybody have an exhaust from LMC?
Also, does anybody have pics of the stock 454 y-pipe and catalytic converter so I can get an idea of how it's plumbed? |
Parts and more parts
Buy a set of highflow cats and put them just down stream of the headers or exhaust manifolds, depending on wht you are running.
