Old 01-19-2006, 02:41 PM   #1
sdkid
Power brakes
My truck is a 1970 with 4-wheel drum brakes, non power. What is needed to convert to power? Booster, rod, brackets, MC. What else? Do I need to swap prop valves? Pedal? Is a drum booster different than a disc booster? And what do I need to look for to get the smaller diameter booster I've seen on some pickups?
I also found a 89 chevy van. Can anything be used from this to convert to disc?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-19-2006, 05:29 PM   #2
pharcydekm
Re: Power brakes
I bought a booster for a 73 chevy truck. $85.00 Then bought the bracket from
http://www.****************.com/
$150.00 Used the same proportion valve and worked great. Now I'm converting to disks mainly for the look and will be changing the master and proportioning valve.
Night and day from manual to power even if you keep the drums all the way around
pharcydekm is offline   Reply With Quote
Old 01-20-2006, 03:23 PM   #3
dennislbrooks
dennislbrooks's Avatar
Re: Power brakes
no change in splitter block needed unless you go to disc brakes in front then you would need a proportioning valve
dennislbrooks is offline   Reply With Quote
Old 01-20-2006, 04:10 PM   #4
pharcydekm
Re: Power brakes
sorry not sure why that link did not show up. It is ****************.com
Old 01-20-2006, 04:11 PM   #5
pharcydekm
Re: Power brakes
ah maybe because he is a competitor with an advertiser or something. his name won't even show up . Weird!
Old 01-20-2006, 04:35 PM   #6
sdkid
Re: Power brakes
It will stay drum for now. Disc would be nice in the future though.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 01-21-2006, 01:08 AM   #7
lvscott
Re: Power brakes
Wasn't there a thread somewhere on this board about someone using a 73+ brake booster on their 67-72 truck to get power brakes?
lvscott is offline   Reply With Quote
Old 01-21-2006, 04:19 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Power brakes
Here is one, I don't know if it's the one but it may be. If you click on the search button on the top of the page your post is on and type in a keyword or words like "power brakes" it should take you to some threads. V. V.
http://67-72chevytrucks.com/vboard/s...t=power+brakes
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-05-2006, 12:05 AM   #9
dennislbrooks
Re: Power brakes
here is my orig but they killed it--probably by mistake
http://67-72chevytrucks.com/vboard/s....php3?t=162730
Old 02-05-2006, 04:13 PM   #10
lvscott
Re: Power brakes
i resurected your original. http://67-72chevytrucks.com/vboard/s...d.php?t=162730
Old 02-05-2006, 04:21 PM   #11
dennislbrooks
Re: Power brakes
thanks Ivscott-----sdkid, here is another pic. Remember if using stock pedal arm hole. from firewall mount to center of the booster rod hole is 8.5" Rod will allow for lengthening using split washers if needed. Hole may need enlarged on rod.
Old 02-05-2006, 07:27 PM   #12
SOMAD
SOMAD's Avatar
Re: Power brakes
i have the complete power brake setup off my suburban peddle and all disk front drum rear. Im doin an underdash setup on mine. All my stuff has been replaced except the proportioning valve but the brakes worked perfect. PM me for more info.....
SOMAD is offline   Reply With Quote
