01-19-2006, 11:33 PM | #1 |
Replacement seat question....
In my 72' my seat is kind of cruddy, the foam is shot, the covers shot. For the price it costs for new foam, and vynel and sand blasting the brackets and painting im thinking it would be smarter to find a bench seat out of somthing newer, probably a pick up. Anyone have any details on what you have, and how you did it? Do you have pics? any info is a help, thanks guys...
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
01-20-2006, 12:07 AM | #2 |
Re: Replacement seat question....
I have seen several posts with pics of suburban seats and lots of 90's benchseats... I am planning the same move in a short while...
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
01-20-2006, 11:28 AM | #3 |
88-98 bench or buckets or 60/40 or 40/60 will fit. I chose to cut the frame down on mine so it sit below the rear window. They are simple to install drill 4 holes and use a large thick washer on the underside of the cab floor when bolting the seat in.
Also 90's ford benches can be made to fit and look pretty nice.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-20-2006, 11:59 AM | #4 |
Thats the Hillbilly way
Here is a 98 60/40 , I wouldn't recommend it if you are over 6' and are going to keep the tank in the truck . I also have a Tilt ,and a later model wheel for more room .
You might want to do a Search we kicked this around awhile back .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
01-20-2006, 02:56 PM | #5 |
Anyone know if 73-87 seats will work
01-20-2006, 07:18 PM | #6 |
73-87 seats will not fit properly. Your better off getting the stocker redone.
01-21-2006, 06:45 AM | #7 |
Do the 73-87 seats take more work than the 88 up seats? I'm asking because the seats I want dont have a bracket for a 67-72 but they have 73 up brackets. Here's a pic.
