Big Block Guys.......Average MPG Questions
I am looking at a truck with a Big Block(K20) and was wondering what you guys that are running them average fuel mileage wise. I always wanted a K20, not to mention it will allow me to have a truck while I do all the body work to my C20 Cummins truck. This truck has had a 454 installed running through a 4 spd.
Also, anyone running an NV4500, NV5600, or 6spd ZF behind a big block?
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
Aluminum slot wheels rule...
Re: Big Block Guys.......Average MPG Questions
Don't know mileage, but glad to see that you may be getting a 4x4.
#3 | |
![]() Just concerned with mpg, because I'll have to drive it daily until my Cummins powered truck is finished 100%.
its all about the +6 inches
I 'think' I get about 9 - 11 MPG.
I've only checked a few times, and that's what it was at. Caddy 500 w/edelbrock 750 TH350 and 4.10 gears. |
#5 | |
hahahaha, It's a big block baby. WHO CARES. you the gas and it goes, mmmmmmm POWER
This weekend I was at a local car meet with a board member and his friend said he needed a big block in his 59. But he said it would be a daily driver so gas would suck and his friend looked at him serious and said "ya......but you will have a big block"
If you want power and some gas go with a small block. If you want power and even more power go with the big block.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Active Member
I have a '72 with a 454ci, TH400, and 3.08 gears, City is 6-9, Highway 8-14, keeping in mind I'm on the loud pedal quite often...
Member #1049
My 68 - 3/4 ton 4X4 weighing in at #5890 lbs,with 468 ,T350 trans, 3:73 gears and 35 inch tall rubber gets between 8 - 12 mpg depending on the loud pedal.
My 71 - 1/2 ton Suburban with a stock 454, T350 trans, 3:73 gears gets 11 - 14 mpg My 71 2WD Blazer with a built 454 and close ratio Muncie 4sp. 3:73 gears and short tires gets 8 - 10 mpg .. if you drive it tenderly.. which is hard too do!! Big blocks.... the only way!!.. the only substitute is a Bigger Big Block |
![]() Join Date: Nov 2005
My 396 bb only uses 3-4 gallons a week . Of c12 race gas at the drag strip
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
huh ???
My 72 C/20 has a 396 with a 850 cfm Q-jet 700r4 combo with 4:10 rear and I'm lucky to get 5 mpg...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" Last edited by 72 CustomCamper; 01-23-2006 at 01:12 AM. |
![]() Join Date: Aug 2005
8 city in a 396/400/3.73 Burb. That's with a POS Torquer II manifold and a leaky Holley... Not enough highway miles with that setup to average.
I got about 10mpg short trips, 12.5mpg highway 402/qjet/th400/4.11. Same combo except 1411 edelbrock 10mpg short 10.5mpg highway. Now a ht502/1411/th400/4.11 10mpg short 11mpg highway. Towing 5000lb-6000lb it drops to 8mpg. Really thinking of going back to the Qjet.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Not really so different than my other trucks with a small block believe it or not...
![]() K-20/396/th-350/4:11's/285-16 tires Although the over drive I just installed did change that for the better. ![]() Driving around town is the better fuel saving's cause pushing it down the interstate @ 75mph is getting into the pedal more just due to our trucks superior aerodynamics. ![]() Last edited by vtblazer; 01-23-2006 at 08:34 AM. |
#15 |
Thoes better MPG than my 355 in my 84. Where can I find a big block mabye I can gain a MPG or two ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
