Old 01-23-2006, 08:39 PM   #1
bigjimzlll
bigjimzlll's Avatar
72 spindles on a 67?
OK..I am front suspension ignorant. I ordered 72 drop spindles. Is this a bolt on to my 67? Or am I going to have jump through hoops on this too. I drilled 5x5 rotors to a 5x4.75 pattern. That worked pretty slick.(had a machine shop do it). My friend trying to help out cut 2 1/2 coils out of my 2" drop springs...lol...that didn't work out to well. It sure is low now.....
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-23-2006, 08:51 PM   #2
Z28Owner
Z28Owner's Avatar
Re: 72 spindles on a 67?
You will have to change your upper ball joints to the 71 - 72 style, outer tie rods ends, and you will have to have and adapter to attach to your inner tierods. You say you have disc brakes now are they on your truck now or what are they for? If you can get the 73- 87 spindles it will be cheaper in the long run and parts are more readily available.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 01-23-2006, 11:20 PM   #3
bigjimzlll
bigjimzlll's Avatar
the disc brakes are for a 72
Anderson,CA
