01-23-2006, 01:57 PM | #1 |
Like a Rock!
Slip on cab supports???
What exactly is the advantage of the slip on versus the regular? Has anybody tried these?. Mine are rotted and and I want the easiest ones I can get.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
01-23-2006, 02:01 PM | #2 |
Re: Slip on cab supports???
Run don't walk away from that idea. All the slip-ons do is cover up the problem. The ONLY way to fix these is to buy the non-slip on ones, cut the old ones out, and weld in the new.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-23-2006, 02:08 PM | #3 |
I agree 100%. The only way to stop rust is to remove it. Take the extra time and do it right.
01-23-2006, 02:10 PM | #4 |
Like a Rock!
I thought they still had to be "welded" on to the cab.
01-23-2006, 02:13 PM | #5 |
Very possible, but If you only cover the existing rust you will be repairing it again down the road.
01-23-2006, 02:25 PM | #6 |
Like a Rock!
Thanks for the help.
01-23-2006, 05:12 PM | #7 |
i cut the rusted part out of my truck and left it. now there's a huge drain for anything that gets in the cab supports.
i don't suggest you do the same but i'm poor and don't care. |
01-23-2006, 05:23 PM | #8 |
F.A.S.T. president
the slip on ones are ok as long as the rust damage is not structual hazard. The rear slip on ones arent even close to the correct shape the front are pretty close. But like others have said, it is only a cosmetic cover.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
01-23-2006, 11:35 PM | #9 |
18 Till I Die
Ok . Can you still buy GM?? I have never seen them on ebay. Any other places. Are they expensive and do you have to remove/lift the cab
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
01-24-2006, 10:13 AM | #10 |
F.A.S.T. president
You can buy them from any one of the wonderful venders here. I use Mothertruckers. They are reasonably priced. Yes you do have to remove the cab to do it right, lifting the cab up is not enough unless your just going to "slip" it in place to cover up a rust hole. But I still dont recomend the slip on ones.
01-24-2006, 02:03 PM | #11 | |
