Old 01-24-2006, 05:54 PM   #1
72Short_Cut
72Short_Cut's Avatar
Kill Switch
Yah, im looking to put a kill switch into my truck i was wondering if anyone has any really sweat setups, or good ideas in making a kill switch for ignition or some sort of setup for a electric fuel pump switch.
thanks
- Ryan
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline   Reply With Quote
Old 01-24-2006, 06:02 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Kill Switch
You looking for a quick way to shut off the engine... or a way to deter thieft?
Old 01-24-2006, 07:37 PM   #3
Zonaman
Zonaman's Avatar
Re: Kill Switch
If theft prevention is your goal here's what I did:
I use an Autolock . Harder to cut through the brake pedal than the steering wheel. I also have a fuse on the battery wire to the ignition, under the hood. It's a blown fuse when it's parked. If (when) they get through the Autolock, hopefully, they'll waste a lot of time farting around looking for a kill switch that's not there before giving up or going under the hood- which you can rig up to lock if you like. Certainly not fool proof but a good effort.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 01-25-2006, 12:28 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Re: Kill Switch
Zonaman, they don't list our trucks specifically and I'm wondering what car model works with our trucks? I'm thinking about getting the Autolock X.
EDIT: I figured it out. Turns out the cars they list the Autolock WON'T work with them.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-25-2006, 12:39 AM   #5
truckdude239
truckdude239's Avatar
Re: Kill Switch
if you got hei and rewired the hei can you just install a switch in the hei power wire with switch off nostart lol
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-25-2006, 12:45 PM   #6
Zonaman
Zonaman's Avatar
Re: Kill Switch
I'll take a look at mine and let you know. I just remember picking it up off the shelf at a local Checker Auto.
Old 01-25-2006, 12:56 PM   #7
junkyardjohn
junkyardjohn's Avatar
Re: Kill Switch
If You Put A Kill Switch In Line On The Purple Wire That Goes To Your Nuetral Safty Switch, It Will Shut Down The Ignition Switch When Activated. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-25-2006, 01:08 PM   #8
shifty
Questionable
shifty's Avatar
Re: Kill Switch
I was thinking about using a floor-mounted high beam switch for a kill switch the other day. It looks natural and when activated, truck won't start (wire as JYJ mentioned).
Just a thought. I'm going to have lojack in my truck, so ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-25-2006, 05:04 PM   #9
farside847
farside847's Avatar
Re: Kill Switch
I always thought this thing was cool: http://www.cardefender.com/home Its a proximity kill switch.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-25-2006, 05:25 PM   #10
68haywagon
I'm watching you!
Re: Kill Switch
I like that one!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
