Old 01-28-2006, 06:16 PM   #1
krue
Designated A-hole!
krue's Avatar
Unhappy Tranny leak question
My th350 is a leaker and I'm sick of it. I need to know what seals the shift linkage? I've got to replace the o-ring on the speedo gear and the shift linkage, but I don't have a clue what seals the linkage or how to replace it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-28-2006, 06:38 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Tranny leak question
It's called a shift shaft seal. It's a tiny lip seal. Removal and replacement requires a special tool set. K-D tools sells both the remover and installer for 18 bucks. Well worth it too. Any other method and you risk putting a nick on the shaft and ruining the new seal too.
Remember, the speedo has two seals. One inside the bullet and an o-ring around the bullet. Usually, the bullet gets worn as well as the gear, so repair is a new bullet and gear both. Again, under 20 bucks.
Here's a picture of a new bullet and gear that I installed a couple of weeks ago.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-28-2006, 06:41 PM   #3
Tx Firefighter
The tools:
http://www.sjdiscounttools.com/kdt2393.html
Old 01-28-2006, 07:16 PM   #4
krue
Designated A-hole!
krue's Avatar
Where can I get the new bullet? Do the part stores carry them? Mine doesn't have a seal on the inside (which probably explains the leakage). BTW I need to change my gear ratio (speedo reads slow) but I can't figure out what color this is? The driven gear is brown (18 teeth).
www.daveramsey.com
Old 01-28-2006, 07:20 PM   #5
Tx Firefighter
You can get a bullet from GM or any decent transmission shop (not chain store trans shop, greasy hands, dirty walls place)
Pull your tailhousing off and count the teeth on the drive gear.
Can you tell I did a trans job recently, with all the handy pictures I have?
Old 01-28-2006, 07:25 PM   #6
krue
Designated A-hole!
krue's Avatar
How big a pain is it to pull the shaft off with the tranny in the truck?
www.daveramsey.com
Old 01-28-2006, 07:26 PM   #7
krue
Designated A-hole!
krue's Avatar
BTW does any chainstore carry KD tools? I don't mind paying 17 bucks, but 10 bucks shipping is a little steep.
www.daveramsey.com
Old 01-28-2006, 08:13 PM   #8
Tx Firefighter
You don't pull the shaft at all. Just remove the tailhousing off the trans. Just unbolt it and tap it slightly with a mallet and it will come right off. That will leave the shaft sticking out like in my picture above.
I don't know who sells the K-D tools. Mine are Kent-Moore, which is GM's brand of specialty tools. I'd rather not say where mine came from.
Try doing a search on selector shaft seal tool or something. I'm sure several companies make the tools too. I just used KD because google turned it up first.
Old 01-29-2006, 12:51 AM   #9
krue
Designated A-hole!
krue's Avatar
O'Reilly's is gonna order it for me (I knew I remembered seeing KD tools somewhere).
www.daveramsey.com
