Old 01-27-2006, 10:26 AM   #1
aitch
aitch's Avatar
Hidden hitch, rear roll pan
I'm looking for some input on how best to install a hidden hitch and find an appropriate roll pan that will work with this set-up.
I have looked at the Sir Michaels and think that the tag box sits too low. I like the look of the Mar-K roll pan but don't know what is involved with notching the rear seal to accomodate the tag box.
I would appreciate some ideas from all you guys who have been there done that.
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 01-27-2006, 11:09 AM   #2
NPilot1975
NPilot1975's Avatar
Re: Hidden hitch, rear roll pan
I am running a Sir Micheals roll pan and had a hidden hitch made. Below is a pic before the roll pan was on. I cut a hole through the license plate bracket and run a flip-up license plate bracket over it. Works great and you can't tell it is on there when I don't have a receiver in it.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-27-2006, 01:28 PM   #3
72MARIO
72MARIO's Avatar
Is that the ECE rear crossmember ?
I have that in my truck neat way to fab up a light duty hitch. How is the hitch fastened to the rear crossmember ? Weld or bolted ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-27-2006, 07:56 PM   #4
ebfabman
Here's more on another hidden hitch......
http://67-72chevytrucks.com/vboard/s...d.php?t=174123
ebfabman is offline   Reply With Quote
Old 01-28-2006, 04:32 PM   #5
NPilot1975
NPilot1975's Avatar
It is actually fully welded, behind the back 1/4 steel piece is a 2 1/4" steel square tube. It has 1/4" steel plates that go inside the frame rails and are bolted to the frame. It is actually stronger than your standard Reese style hitch. I pulled an 18' trailer with a truck and an engine and tranny on it with no problems from IN to FL. I am tearing my truck down in the next few months, when I do I will take more pictures with it out and give some dimensions.
Old 01-29-2006, 09:54 AM   #6
aitch
aitch's Avatar
Good information, anyone have experience with a Mar-K roll pan in this application? Pictures?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
