Shot in the dark - Explain my transfer case
Hi,
I know this is a bold shot in the dark, but can you help me identify my transfer case? I have a '72, K20, 350/th350, 8-bolt wheels with 9/16" studs. I'm not currently able to look at my transfer to tell, but can you explain some differences in original transfer cases available? This is so when I get home, I can say "Yeah, that's what they were talk'n about" :-) TIA, W Last edited by dubya; 01-30-2006 at 06:11 PM. |
![]() Join Date: Feb 2000
Re: Shot in the dark - Explain my transfer case
If it's a true '72 drive train it will be a NP205. It will be a cast iron case. The rear bearing retaining cover (to the right of the rear output yoke) will be aluminum. The shift pattern (front to back) 4lo, N, 2hi, 4hi. Hope this helps some.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Thanks that's what I have. 4lo, N, 2hi, 4hi pattern, and aluminum cover...
Follow-up questions: The bolt pattern where the tranny meets the case looks to be a square-oval, and not a road-race track pattern (not symentric around the center). I'm thinking of swapping to a NV4500 if I can get the war-dept. (wife) to pony up some cash. I have a non-stock 400sbc in it now. Any gotcha's, neat tricks, major problems that I may encounter? Does the NV4500 marry up to the motor, or is a adapter/new bell housing in my future? I'm considering going with stock linkage for the '72, and adapting that to the tranny, but I've seen where guys stuck with the hyd. linkage. I'm sure it comes down to preference and maintenance, but what's better? TIA... Maybe I should make a new thread for my followup ???? W |
#4 | |
if it is indeed a TH350/NP205, then it will be the racetrack bolt pattern. a NV4500 won't just "bolt up."
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
And you can't run a mechanical linkage clutch with the NV4500 without a lot of modification because it's set up for hydraulic. There won't be a clutch arm and pivot point on the transmission.
72 GMC K20, 454, TH350 00 GMC Yukon 66 Ford Bronco |
Which brings me back to one of my questions:
will a NV4500 bolt into a '72 bellhousing? If you look here, you can see the nuckle/clutch arm hole. http://cgi.ebay.com/ebaymotors/68-72...ayphotohosting |
I thought that the NV4500 had an integral bellhousing.
#8 | |
![]() Join Date: Mar 2003
