![]() Join Date: Feb 2005
Ignition Bezel
Can anyone out there tell me how to get the ignition and bezel apart to get it out of the cab? It seems like there must be a trick to it. It just spins and if you hold it with channel locks it still will not come apart. HELP!
Re: Ignition Bezel
1st put it back like it was so it will hold itself. Insert key and turn to acc. Take a paperclip and insert in hole that is in key cylinder and push in and turn key to left at same time. Cylinder will now pull out with key.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Cantankerous Geezer
Re: Ignition Bezel
![]() After you get the cylinder out, the bezel will come off. There is a flange on the cylinder to make it harder to pull the switch without the key. This tool helps keep from destroying the bezel. http://www.myoldtruck.com/vboard/showthread.php?t=6562
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: Ignition Bezel
Some jiggling may be required during the process.
#5 | ||
Son Of Gravel Man
Re: Ignition Bezel
![]() That could explain a few things ![]()
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
Re: Ignition Bezel
I spent a good 3 hours getting my old one out. Lots of "jiggleing the handle" if you know what I mean....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Re: Ignition Bezel
what if you lost the key? Is it still possible to get it apart?
More Cowbell....
Re: Ignition Bezel
Cordless drill and a sharp bit will assist in that case /\
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#9 | |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Ignition Bezel
Re: Ignition Bezel
What part needs to be drilled out?
Re: Ignition Bezel
Ok I will try that.
Thanks |
