Old 02-01-2006, 01:43 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Rattling drive shaft. I think.
When I put in the clutch to slow down, I can feel and feel rattling or chattering that slows and stops with the drive shaft.
This truck has set for 2+ years, so it is possible that it needs u-joints. I did grease them all, but haven't had a chance to drive it much since. I was wondering if my drive shaft bearing could be the problem. I don't know what you can tell from the picture, but any info would be welcome.
Thanks in advance
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-01-2006, 01:47 PM   #2
farside847
farside847's Avatar
Re: Rattling drive shaft. I think.
Roll under the truck and try to wiggle the shaft. It should move only a little. If it moves alot (like 1/2") the center bearing is shot.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-01-2006, 01:52 PM   #3
boundstaffpress
It moves, I don't know about a half inch. It will come up and close the 1/4" gap by the rubber bushing.
Justin
Old 02-01-2006, 02:21 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
I'd replace the carrier bearing
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-01-2006, 02:23 PM   #5
farside847
farside847's Avatar
There should not be a gap between the bearing and the rubber. It should be attached and all one piece. Looks like you need a new one. New ujoints while your at it might be a good idea too. Its not too hard to do. Here is a link when I did it: http://67-72chevytrucks.com/vboard/s...d.php?t=171772
Old 02-01-2006, 03:35 PM   #6
Hook'em
Hook'em's Avatar
I just bought a carrier bearing because mine is shot. Started out as a slight rattle and turned into a serious clanking really fast. Can you hear the rattle when you move the driveshaft? Also, mine only made noise moving forward.
Hook'em
Hook'em is offline   Reply With Quote
Old 02-01-2006, 03:58 PM   #7
boundstaffpress
Mine only makes noise in forward gears as well. Looks like I'll be buying a new one.
Does NAPA carry these?
Justin
