Old 02-01-2006, 05:08 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Gear Ratio Question
I'm running a stock Saginaw 3 speed and all the info that I've found on it says the gear ratio runs from 2.56 in first gear to 1:1 in third gear which is pretty darn tall.
A mild-performance 350 is just about dropped in my truck and I'll probably go with shorter gears. (swapping the trans is not an option right now). Is that just a matter of swapping out the ring and pinion? If so, how hard of a job is it to do in a home garage without any power tools? Also, what ratio would you all recommend?
John
Ole Blue 68 is offline   Reply With Quote
Old 02-01-2006, 07:13 PM   #2
farside847
farside847's Avatar
Re: Gear Ratio Question
Probably a 3.08 rear would work nice. From what I hear it is not very easy to do for a weekend warrior, so I decided to have a pro do it.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-01-2006, 07:51 PM   #3
MrC1
Dork For Days
MrC1's Avatar
All non-overdrive trannys are 1:1 in top gear.
You didn't mention what rear you've got, but they all pretty much require use of power tools to rebuild. The pinion nut comes to mind as the biggest culprit needing quite a bit of torque to remove. Also, if you've not done one before you may want to pay someone to do it. This is one of those jobs you just don't figure out by tearing it apart and throwing it back together.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 02-01-2006, 08:48 PM   #4
dwaite72lnghrn
I would say first is, What RPMs do you want to run in? Second, How mild a 350 do you have? Stock or near stock? Third what rear do you have now?
I don't think that 3 speed will hold up if you start dropping the hammer at 3-4 grand. So you might be putting something in anyway. The ratio of your 3 speed covers about the same as all 4 speeds(granny low excluded because it is not syncrod) they just give you more inbetween gears. Autos cover the same except for the 700r4 which has a lower 1st. JMO
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 02-01-2006, 09:00 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a website with the info you want plus a ton more. The ratios are on the first page.
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-02-2006, 01:03 AM   #6
Ole Blue 68
Thanks for the good feedback and the good questions raised.
The engine's going to be modded and I'm hoping to hit 300hp at the wheels(we'll see). As far as the rear goes, it's just the stock rear (14 bolt, 10.5 inch?) with six lug axles. Even with the old motor, I could get some nasty launches out of first gear but it's not very practical and a lot of times I don't even bother with first. I want something that's still gonna give me good low end torque but not feel like I'm tearing the thing apart. So I was thinking a 3.08 might be the way to go just as Farside is suggesting.
It's also good to know that I might be in over my head if I tried it so I will leave it to an expert.
dwaite- you bring up a good point about the 3 speed holding up and I have the same concerns but since I just dropped a good chunk of change on the engine, I'm gonna have to keep my fingers crossed that the old Saginaw holds out for a while.
Old 02-02-2006, 12:21 PM   #7
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
This chart shows you your RPM at 60 mph for different gear ratio's and tire size . Hope it helps .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 02-02-2006, 02:24 PM   #8
Ole Blue 68
Huge help, thanks Bill!
