Aluminum slot wheels rule...
Re: How to move a non-tilt column forward.
TP, I'll admit it. I have a fat gut and need the space.
#2 | |
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
#3 | |
![]() SO if I am understanding this right, you can drill the plugs out, slide the column ahead, and it will be fine? I don't need to put bolts through the shaft to hold it together? |
Correct! The plastic is there in case of accident the steering column can collapse a little.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
