Old 02-06-2006, 02:56 PM   #1
chevykevy
chevykevy's Avatar
Drums to Discs Question?
I would like to put disc brakes from a 71 on my 68. Can I use the 68 Control arms? How about putting a booster on. Can I use the existing brake bias valve? What else do I need to consider?
chevykevy is offline   Reply With Quote
Old 02-06-2006, 03:27 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Drums to Discs Question?
keeping it 6 lug
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
swapping to five lug
http://67-72chevytrucks.com/vboard/s...d.php?t=160435
Hope this will answer your Q's
sneakysnake is offline   Reply With Quote
Old 02-06-2006, 05:56 PM   #3
RicksTrucks
RicksTrucks's Avatar
But if you take the whole front crossmember from a 71-72, do you have to worry about control arms, etc.?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 02-07-2006, 03:15 AM   #4
Ol'blue72
Yesterday I pulled the power booster, proportioning valve and all from my 71 an put it on my 72 that already has discs, am i going to run into any problems?
Ol'blue72 is offline   Reply With Quote
Old 02-07-2006, 03:57 AM   #5
krue
Designated A-hole!
krue's Avatar
Shouldn't have any problems, should be identical to the 72 stuff.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-07-2006, 03:58 AM   #6
krue
Designated A-hole!
krue's Avatar
You shouldn't have to worry about any of it.
www.daveramsey.com
Old 02-07-2006, 09:34 AM   #7
c10crazy
Like a Rock!
c10crazy's Avatar
Can you keep 6 lugs while using any 71-72 stuff?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 02-07-2006, 11:17 AM   #8
dennislbrooks
dennislbrooks's Avatar
you can stay 6 lugs -- there are choices and also you will have to deal with the outer tie rod ends if you retain the 68 steering link--both can be overcome
dennislbrooks is offline   Reply With Quote
Old 02-07-2006, 11:29 AM   #9
c10crazy
Like a Rock!
c10crazy's Avatar
Hate to sound dumb but I want to stay with 6 lugs. What specific parts do I need from the 71' and what else do I need to buy??
69 LWB
Old 02-07-2006, 11:37 AM   #10
dennislbrooks
well you can buy the McNaughy's rotor kit or ------- we are pretty sure that a GMC 88-91 3/4 ton Light Duty 6 lug is the match made in heaven. I know for a fact that a 71/72 rotor fits on the 88 3/4 ton van LD spindle (bearings are the same A5 inside and A3 outside. Just a matter of which caliper to use -- and maybe that does not make a difference either. One good thing is you can take them back to Oreilly's for refund. I have 6 lugs and disc all the way around on my 67.
Old 02-07-2006, 11:55 AM   #11
c10crazy
Like a Rock!
c10crazy's Avatar
Ok, so I buy the 1988 6 lug rotors and calipers. What other parts do I need from the 71'? chevykevy I hope I'm not hijacking and hope this helps you too.
69 LWB
Old 02-07-2006, 12:12 PM   #12
dennislbrooks
I would try the 71/72 caliper and pads first ---- bearings and seals , 71/72 flex hoses --you need to modify the 71/72 outer tie rod ends if you are using the 65-70 steering link ---see link below
http://67-72chevytrucks.com/vboard/s...d.php?t=188551
And I assume you know you need to use balljoints for the 71/72.
Old 02-07-2006, 12:38 PM   #13
c10crazy
Like a Rock!
c10crazy's Avatar
Sounds like I use everything from the 71' except the rotors.
69 LWB
Old 02-07-2006, 12:44 PM   #14
dennislbrooks
let us know how it works out --- I believe the rotor thickness on the 71/72 is 1.25" and the 88 is 1.28" --- if pad clearance is too close the rotor can be slightly shaved -- probably not needed tho
Old 02-07-2006, 01:04 PM   #15
1969owner
1969owner's Avatar
im doing this shortly.......im gonna get the entire 73 front end, with power steering etc, and put 6 lug rotors on it, and let her loose. with a lil riggin, anythings possible.
1969owner is offline   Reply With Quote
Old 02-07-2006, 01:05 PM   #16
c10crazy
Like a Rock!
c10crazy's Avatar
Thanks man. I'm going to try searching the board for some kind of list I can print out to see exactly what I need and what I can keep. I'm suspension illiterate
69 LWB
Old 02-07-2006, 01:26 PM   #17
1969owner
1969owner's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=188429
Old 02-07-2006, 02:06 PM   #18
boraxman
Keepin an eye out
boraxman's Avatar
Careful using '71 parts, I found out while doing my conversion that some if not all? 71 rotors are 1"...so using 71 calipers on 72 up rotors wont work.
Someone correct me if im wrong here
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-07-2006, 03:13 PM   #19
dennislbrooks
agree, anything is possible -- I have found that usually the 1 " rotors are LD and take the A6 inner bearing instead of the larger A5 --had not seen this on a 71 oem --but who knows what someone changed on these trucks before we got them.
