Old 02-05-2006, 06:41 PM   #1
1969owner
1969owner's Avatar
Smile 73' on a 69'?
hi,
i was wondering if i could take the 5 lug front and rear end out of a 73' c10 and put it under a 69' c10? will this work?
1969owner is offline   Reply With Quote
Old 02-05-2006, 09:10 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73' on a 69'?
Yes and maybe! You can do the entire front crossmember swap with no problem. I should say minimal trouble. You will have to mod the brake lines since they come in differently.
The rear is a maybe. It won't bolt in unless your 69 has leaf springs. If I remember correctly all 69's were coil spring rears (assuming you are talking about a 2wd). You can modify the mounts to work, but there still might be a catch. I think it was 69-70 that had two different width rear ends. You will need to verify that the rear ends are the same width....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-05-2006, 09:56 PM   #3
1969owner
1969owner's Avatar
Re: 73' on a 69'?
ok, i have the coil springs. thats good news. and its 2wd, any special (kit) i can buy to modify the brake lines?
Old 02-05-2006, 10:06 PM   #4
1969owner
1969owner's Avatar
Re: 73' on a 69'?
brain fart. ill just get the frontend, buy six lug rotors, not mess with the rearend!
Old 02-05-2006, 10:07 PM   #5
mooneyes
mooneyes's Avatar
Re: 73' on a 69'?
u can do it one of 2 ways...you can swap the whole thing..belly pan and all or just swap the spindles ..rotors..calipers..brake hoses and steering linkage...and you'll have to buy new ball joints ...and i would just run new brake lines in the front........
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 02-05-2006, 10:16 PM   #6
1969owner
1969owner's Avatar
Re: 73' on a 69'?
ok
Old 02-05-2006, 11:26 PM   #7
longhorn71
longhorn71's Avatar
Re: 73' on a 69'?
the 73+ rear ends.are all leafs,you could cut the mounting pads off the old one and weld them to the 73+ rear.The only problem is the panard bar(track bar)the 73+ rears do not have a place to bolt them on.Find a 71-72 rear and bolt in.or pull the 6 bolt axles and have them re-drilled with the 5 lug pattern
longhorn71 is offline   Reply With Quote
Old 02-05-2006, 11:52 PM   #8
1969owner
1969owner's Avatar
Re: 73' on a 69'?
im just gonna use the frnt end, ill put 6 lug rotors so i can keep my western turbines. itll be easier, less modifying
Old 02-06-2006, 12:22 AM   #9
SCOTI
SCOTI's Avatar
Re: 73' on a 69'?
Originally Posted by N2TRUX
.... You will have to mod the brake lines since they come in differently.
You can use the brake lines from the donor vehicle as well. They fit w/only minor tweaking required but the proportioning valve will be mounted in a different location than stock 67-72's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-07-2006, 01:28 PM   #10
1969owner
1969owner's Avatar
Re: 73' on a 69'?
and by getting the 73 front end, ill have power steering. less strain,more gain.
Old 02-08-2006, 02:28 AM   #11
longhorn71
longhorn71's Avatar
Re: 73' on a 69'?
if you run the 73+ pump you need to swap to a long water pump,brackets,pulleys and move the alternator to the passanger side.
