02-06-2006, 04:52 PM | #1 |
wtb: eaton 3rd
I think I may have posted this before, but thought a follow up might be due. I am trying to find an eaton 3rd with 4.10's and a posi setup. I have a 4.56 with an open rear.....and after sometime in the mud this weekend, I would like to upgrade. If you are willing to ship let me know, otherwise, please be within a reasonable driving distance.
Thanks!
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
02-06-2006, 06:49 PM | #2 |
its all about the +6 inches
Re: wtb: eaton 3rd
well, I have a 4.10 out of a 72 longhorn, it's an open diff though. A dude was supposed to swing by last month to get it, I PM'd him and have heard nothing.
I was gonna get 100 bucks plus ride or pick up locally. I guess since he is like a month late with no contact... I can sell it if you are interested. I don't know if you figure 190 miles as fairly close or not... but I'm in Columbus straight south of you. |
02-06-2006, 11:02 PM | #3 |
Having issues
Re: wtb: eaton 3rd
stick with the 4.57's and buy a detroit locker for a 14B. Buy stock shafts as well for the 14B, stuff it all in, and you are gravy. The 14B stuff will work in an eaton, its been tried, and is true. There was no posi available as far as I know for the eatons, so either you go with a detroit, weld the spider gears (lincoln locker) or stay open.
The detroit fits inside the two piece carrier, so you dont have to pay to have your gears reset. Its a fairly simple locker to install. Check fleabay, they pop-up from time to time, ranging from $300-400. The 14B detroit and shafts are stronger than the eaton detroit btw.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
02-07-2006, 08:36 PM | #4 |
Re: wtb: eaton 3rd
While the upgrades you mention all make sence...why stay with a 4.57 on atruck that sees freeways more than mud?
02-08-2006, 01:37 AM | #5 | |
Having issues
Re: wtb: eaton 3rd
02-08-2006, 11:52 AM | #6 | |
Re: wtb: eaton 3rd
The 14 bolt stuff fitting in though is very interesting, and if there is documentation or pictures to prove it, then it would be worth buying that stuff rather than search forever for a rare original eaton locker.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
02-08-2006, 12:31 PM | #7 |
1968 C20 Vortec Beast
Re: wtb: eaton 3rd
Eaton made what was called a "no-spin" 3rd member for the H052 eaton axle. mainly for the 4wd and 1ton. My records indicate that is was only available in 4.11 and 4.56 ratios. This makes it almost impossible to find but it was factory in some.
By the way, my records are the original GM Parts Catalog.
Ugly or not it still kicks a**! |
02-08-2006, 02:34 PM | #8 |
72 C30 Trailer Queen
Re: wtb: eaton 3rd
I have a 4.10 center section with the adjustable pinion load deflection bolt, and factory No-Spin (or detroit locker). The unit was factory in a 1972 K20 Super Cheyenne that I once owned. I put about 500 miles on it in 2004 in my 68 C30, but then changed to a 4.10 open.
No one is stepping up with one for sale, so I will offer mine. $400 plus shipping. You can figure a box 18x18x28 at 149 pounds if you would like to figure out shipping. FedEx ground or DHL are probably the best options, usually something that weight has to go to a business address.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 02-08-2006 at 02:35 PM. |
02-08-2006, 02:41 PM | #9 |
Re: wtb: eaton 3rd
[QUOTE=masterbeavis]The 14B stuff will work in an eaton, its been tried, and is true. There was no posi available as far as I know for the eatons, so either you go with a detroit, weld the spider gears (lincoln locker) or stay open.
Reider Racing now offers a mini spool for the 14 bolt. Starting at $179.95. I'm planning on using one in the eaton for my mud truck. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
02-09-2006, 01:17 AM | #10 | |
Having issues
Re: wtb: eaton 3rd
[QUOTE=4bynut]
JKU72: No need for pics of the 14B stuff in an eaton. It works, it has been done before many times, its called a hybrid eaton. People dont talk about it here because they dont know about it, are interested in using origonal parts instead of thinking outside the box to make something work, and make it better (for the most part) Some people report that you have to get a 3/8" spacer made for the hubs because the shaft is too long in some instances. One fix involves 5 minutes and a metal cut off saw. If the splines run short, then you need the spacer. I *think* all 14B shafts are the same legnth, but its a good idea to measure what you have before you buy instead of take my word for it.
02-09-2006, 01:59 AM | #11 |
Re: wtb: eaton 3rd
The swaps been discussed here for years... lockers in 14ff to eatons - vice-versa......lots of threads on it in pirate4x4 site also.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 02-09-2006 at 02:00 AM. |
02-09-2006, 03:00 AM | #12 |
Having issues
Re: wtb: eaton 3rd
I am just in awe of the general population here wanting origonal parts, and paying SOOOO much for them. i.e. who wants to pay $300 for a set of tow hooks when you can buy the same thing from walmart for $20 a set? $60 and up for a stock set of rear seat brackets.... Heh, who wants to pay $9,999 for a no spin, when you can buy the entire axle with it equpeed with one for less than $4,999 (read that as half the cost(or less) of the no spin), or for the same $9999 buy the 14B one. I dunno, I guess I am just spoiled by the fact that the people I get my parts from think I am doing them a favor by getting the "junk" off of their property.
Shelby: If you were closer, I would trade you straight across my 4.10 for your 4.57 and help you find the upgrades like I mentioned, prolly would be around $400 for the parts to a bullet resistant turnkey axle.
