converting from sm465 to trubo 400
I have a 72 gmc that im putting a turbo 400 in. It has a sm 465 in it right now. I bought all the adapters for the transfer case and input shaft and so on. What else do i have to do to the trans mount and transer case mounting?
thanks daniel jones |
Re: converting from sm465 to trubo 400
If its the same as the turbo 350 everything should just line up using the same brackets and holes.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#3 | |
i think that the turbo 400 is a little longer. Can you just slide the crossmember back? |
#4 | |
![]() Join Date: Mar 2003
#5 | |
thanks took care of it last weekend just slide it back and welded it up. Hope its were its supposed to be. Im putting a 475 hp sb in it with a turbo 400. should go pretty well it made over 500 ftpds of torque to. |
Don't weld it to the frame! What if you have to take it back out?
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#7 | |
it should'nt have to be moved hopefully if it does i guess ill have to cut it out thanks |
