Old 02-10-2006, 07:35 PM   #1
DucksChevy
DucksChevy's Avatar
New tires
I need a new set of tires. I have a '69 Chevy Dually. I've never owned a dually before, anything special about these wheels? The guy I bought it from said something about them being a two piece wheel? Can someplace like Sears replace them or do I need to go someplace else?
thanks
don
DucksChevy is offline   Reply With Quote
Old 02-10-2006, 07:40 PM   #2
RANDY COX
RANDY COX's Avatar
Re: New tires
Don't know about the wheels but WELCOME from another Virginian where about's are you located.Thanks Randy
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-10-2006, 07:44 PM   #3
DucksChevy
DucksChevy's Avatar
Re: New tires
Richmond, VA
Old 02-10-2006, 07:52 PM   #4
Huskerboy2
Re: New tires
I actually have the exact same question. My '68 dually is up for tires as well. The tire size on them currently is 7.5 16's. I'm finding these pretty hard to find. Don, is that the size you currently have on your dually?
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 02-10-2006, 08:09 PM   #5
DucksChevy
DucksChevy's Avatar
Re: New tires
This is what's on there now.
P235/70R16 104S
Old 02-10-2006, 08:23 PM   #6
truckdude239
truckdude239's Avatar
Re: New tires
you have a split bead rim acorroding to the po no sears can not install tires on a split bead rim split bead tires also have tubes in them you have to find a tire shop that has a cage because it is illeagel to inflant spit bead rims unless they are in a cage because the bead can pop off. at camp we had a truck like this and we installed 265-75-16 on it. post pictures of the front of the rim taht you see and i'll be able to tell you if you have spit bead rims
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
truckdude239 is online now   Reply With Quote
Old 02-10-2006, 08:40 PM   #7
DucksChevy
DucksChevy's Avatar
Re: New tires
Not a great picture, but can you tell from this?
Old 02-11-2006, 04:18 AM   #8
rwgregory
Re: New tires
I own a Ford dually and a good size tire is 215/85R-16. Those tires are tall so
you can go freeway speeds and are also narrow enough to allow ample room
between the two tires in dually mode. If you do have split rims any tire shop
that works on large trucks is set up to do the job.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 02-11-2006, 07:59 AM   #9
69sss4x4
Re: New tires
What ever you do, be careful with them split rims, they can get somebody hurt without a cage.
let the rough end ride and the slick end slide
69sss4x4 is offline   Reply With Quote
Old 02-11-2006, 09:41 AM   #10
truckdude239
Re: New tires
yes i beleve they are split rims from what i can see try any truck stop just have your tires with you i would recomend 215/85/r16 or 235/85r16 tires
David fuller
2000 Tahoe 5.3l 378
