Old 09-20-2002, 02:12 PM   #1
R&R
Question cooling question
Would a two row radiator and a shroud be enough cooling for a sb 400 without a/c? Thanks.
'68 C/10, SWB, 396/350, PS, PB, A/C
'68 C/10, SWB, 400sb/350
R&R is offline   Reply With Quote
Old 09-20-2002, 02:22 PM   #2
MikeB
MikeB's Avatar
Probably, if it's not clogged up. My 383 has A/C and a new 2-row radiator. It's marginal in the Texas summer, heating up to 220 degrees in traffic with the A/C on. I think boilover temp with a 50/50 mix and good pressure cap is around 250 degrees, so I'm still OK at 220. Once I'm moving, the temp drops to around 190. If I had to do it again, I'd get the 3-row. Just as important are a good water pump (I have a Stewart), fan clutch, and fan shroud.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-20-2002, 06:35 PM   #3
72step
72step's Avatar
I'm running a 4-Row on my hyped 327, and it never passes cool-normal. Previously I had a 2-Row, and it would heat up.
72step is offline   Reply With Quote
Old 09-20-2002, 10:06 PM   #4
slam33
slam33's Avatar
An alluminum 2 row w/ 1 inch tube might do it.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-20-2002, 11:49 PM   #5
truckster
truckster's Avatar
You might get away with it, but why take the chance? I'm building a 400sb for my 70, and it's getting a 4-core. The worst enemy a 400 has is heat, and it's getting harder to find good blocks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
