Old 02-11-2006, 02:08 PM   #1
Andy4639
Old member
Andy4639's Avatar
Brake Job
OK I took the 71 to have all the brakes checked, and to have the A/C fixed. Fixing to go out of town for about 30 day's. So I wanted to make sure it was ready to go. What did I find.
Brakes are shot. Over 300,000 miles on the truck.
Problems: Rotor's,caliper's,rear drums, and wheel cyclinders all the original rubber hoses replaced, new pads and shoes.
Rotor's had been turned to many times.
Calipers where stuck, I rebuilt them the last time so I bought new.
While inspecting front brakes noticed front springs didn't look right, guess what both springs where broke, passenger side was broke into 3 peices, driver side was in 2 peices.
Put new 2" droped springs in front, 3" droped in back. New lower ball joints in both sides up front.
One note of interest to all 71 disc brake front ends.
1973 calipers will work on the factory rotors of the truck. The only difference is more hose angle.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2006, 04:59 PM   #2
Boog
laying low
Boog's Avatar
Re: Brake Job
Good thing you had it checked!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-11-2006, 06:27 PM   #3
Andy4639
Old member
Andy4639's Avatar
Re: Brake Job
Yes your right. I had been wanting to get it checked just didn't take the time.While I was there I also got a complete serpintine set up off a 4.3 v-6. Got all the bracket's and alternator,power steering pump,Old A/C. The A/C compressor doesn't work, but I can change mine all out for it and go to the small compressor. Later be able to add headers.
Old 02-11-2006, 06:38 PM   #4
dennislbrooks
dennislbrooks's Avatar
Re: Brake Job
good to know on the 73 calipers what about to 87?-- thanks
dennislbrooks is offline   Reply With Quote
Old 02-11-2006, 09:46 PM   #5
Andy4639
Old member
Andy4639's Avatar
Re: Brake Job
I don't know about anything over the 73. The reason I found this out is the new caliper's from NAPA came in wrong. They sent caliper's for a 73 instead of a 71.
