Old 02-13-2006, 10:24 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
vac gauge
Well, I finally got around to hooking up my vacuum gauge Sunday. I hooked it up to the ported vacuum port on my Edelbrock 1405 carb. Started up the engine and it moved just a tiny bit. Took it out for a drive and no movement. OK, something no workie. (yes, I did buy the correct hose). Tonight I took it off the carb and pulled it through the firewall to do a little test. ( I should have got my wife to do this....) I sucked on the hose to see if the gauge worked this way. It moved to the 10lb mark and got stuck. I tapped the gauge a few times and it moved back to 0. Repeated this a few more times with the same results. Is this something I can easily fix or is the gauge broken?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 02-13-2006, 10:48 PM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
Re: vac gauge
sounds like a bad gauge
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 02-13-2006, 11:31 PM   #3
byrd
Union Electrician
byrd's Avatar
Re: vac gauge
Repop or oem gauge? If oem take out the three 1/4" screw that hold the vac and oil pressure gauge in the dash and remove the two gauges from the dash. Then get some PB blaster(penetrating oil) or similiar product and spray a small amount on the internals of the vac gauge( Do not get it on the face of the gauge) after spraying working the inners GENTLY a little by hand to get the PB all in where is should be and let it set for a while or till the next day. Then spray or apply a small amount of Lithium grease to the inners of the gauge and put it back in and see what it does, if it works which I'm about 90% sure it will then you are out nada,but if it doesn't work then you tried, and you are still out nothing. Most of the gauges I see and that has been a truckload have some rust issuses with the inner mechanicals of the gauge itself and this info has worked sucessfully for me numersous times and most likely will work for you too. Good luck and let us know how it turns out..Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 02-14-2006, 05:51 PM   #4
67Fleet
67Fleet's Avatar
Re: vac gauge
Thanks Randy! I'll give that a go this weekend. A free fix is the best kind and like you said, if it doesn't work, then at least I tried.
-Bret
