02-14-2006, 03:03 PM | #1 |
Cab structure question... What do you guys think?
Alright I need to get the bottom of my cab sandblasted so that I can paint it, however getting under it will be a pain in the arse, basically. With no doors, windows, or anything else on the cab, will it tweak it or hurt it in any way if we carefully tip it up on its front and let it set on the firewall?
I would so it on the edge of my car trailer, so it would have a bit of a slope back, and it would be on a padded cushion, and tow strapped down for stability. I need opinions or expert knowledge here, as I don't want to do this if it risks messing up door fitment etc. later.... thanks in advance, guys -Steve
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. |
02-14-2006, 03:41 PM | #2 |
yeller
Re: Cab structure question... What do you guys think?
You will be fine if you lean it backwards (or forwards)...just don't "throw" it backwards.
I did this on my cab, and didn't have any problems. Be careful when tilting it, the front weighs more than the back (kind of like a TV set).
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 02-14-2006 at 03:42 PM. |
02-14-2006, 03:57 PM | #3 |
I didn't think it would be an issue, Jeff, but I wanted to check...
I would go on the back, but the rollcage bars won't allow it. That's why I was thinking tilting it forward and setting it on the firewall...
~Steve~
02-14-2006, 03:57 PM | #4 |
Professional Grade
Trust Jeff when he says the front is heavy!
Had no idea it was so much heavier up front, so I nearly got squished when it came back down, LOL
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-14-2006, 04:23 PM | #5 |
www.73-87chevytrucks.com
DANGIT, where is the post of that cool cab carrier that someone built out of pipe....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
02-14-2006, 04:24 PM | #6 | |
~Steve~
02-15-2006, 02:18 AM | #7 |
Until Seventy Times Seven
I've seen some use inner tubes to roll the body into them and protect it while working on it. (I wonder if it moves too much while working on it.)
BTW, be careful with that smoothed firewall.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
02-15-2006, 02:39 AM | #8 |
lots and lots 'o padding will be harmed in the safety of the firewall...
~Steve~
02-15-2006, 07:22 PM | #9 |
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 02-15-2006 at 07:22 PM. |
02-15-2006, 07:27 PM | #10 |
wow... that is freaking awsome! I may have to make somethign like that before I get to the bottom...
~Steve~
