Junior Member
![]() Join Date: Jan 2006
Why the different axles lengths?
I am sure this has been asked and answered more than once on here, but I haven't seen it in the recent posts. I think I know the answer, but I'll ask anyways.
Why is the front axle longer than the rear axle on the 4x4's? Also, what would be the correct spacing on the rear to make them look even? Thanks, Mike |
Designated A-hole!
Re: Why the different axles lengths?
What year you got? I know the 70 1/2 up 2wd (which should be the same as the 4wd) rear ends are 1.5 inches wider than the earlier ones. Why? I don't know.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#3 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Not a bad nut after all..
The wider front than rear axle width continued on into the '73-up trucks. I'm also interested in the reason why...
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
![]() Join Date: Jan 2005
I think one of the reasons why I generally like the look of Dodge and import trucks is because the front and rear track widths are the same or nearly so. GM and Ford both had different widths.
I really want to make mine wider in the rear, I don't like the "tucked in" look. Good tip on the 1.5" adapters. Anyone have any experience with how long the axle bearings last with those?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Junior Member
I have a 1972 Blazer. I was told in the past they made them different lengths, so they would track different in mud, snow and so on for better traction. Of course, I dont know if that is the real reason. Thanks for the spacer info. Mike
#7 | |
Any other "reasons" ?? |
I've heard it was to improve turning radius .. no idea if this is true
The Blazer King
I have a 14 Bolt FF rear and mine tracks Even.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#10 | |
I always figured it was just to cut costs by using the same width 12-bolt as the 2WD trucks.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
Which trucks came with 12bolts and which came with 10 bolts what made the difference?
http://cgi.ebay.com/ebaymotors/GMC-C...QQcmdZViewItem http://cgi.ebay.com/ebaymotors/GMC-C...QQcmdZViewItem is this the guy, are these the spacers? Last edited by Medicanman71; 02-11-2006 at 07:10 PM. |
i heard somewhere it helped them turn easier. being that the hind end was narrower then the front they didnt push so much.
-Cameron
1972 Dark blue, Cst, Highlander |
#14 | |
![]() 67-72 trucks did not come with 10-bolts, those arrived during the following generation in the late 70's.
#15 |
thank you!
#16 | |
1972 K/5 Blazer CST - $1 Beast 1993 4.3L S-10 Ext Cab. - 3/4th 350 |
#17 |
i want spacers!
#18 |
The better maybe even the "right" way to do this would be to get different offsets on your wheels. Spacers are not a great idea, especially 1 1/2". If you get 3" backspace and 41/2" backspace you end up with the same effect without the extra stress on studs and bearings. Just my thoughts.
#19 | |
I miss this truck.
But then you have to take the tires off the rims to rotate them. Neitherthat, nor the spacers sounds like a good option to me. How much work is it to swap one axle or the other? Can it be done in a day, if the proper donor axle is used (say, complete from drum to drum, or rotor to rotor)?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#20 |
hahaha, for get swaping axles for a few inches... that's crazy
I just need to get new rims and keep the stock/old ones. |
#21 | ||
Here's the ultimate in decadence... I didn't want to build mine up as a 3/4 or 1 ton. Too heavy for what I was after and you really need 35" or better to have any sort of clearance under a 14-bolt rear. I too didn't want spacers or mismatched offsets... My 12-bolt was dead and I didn't think beafy enough to warrrent a rebuild. In a moment of weakness I called Dynatrac and spec'd out this matched-width D60 rear with disks and a Powr-Loc 70% limited slip. With 16x8" rims and metric 33"s the tires fall perfectly at the edge of the wheel wells. Just the way I wanted it. I wouldn't recommend this for the faint of heart... cost me almost twice as much as I originally paid for the Blazer... ![]() This truck handles way better than it used to... but I've got lots of mods into it so I can't say if the matched track has anything to do with it. This pic has a pretty good angle on the rear...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 02-15-2006 at 11:14 PM. |
