02-14-2006, 09:28 PM | #1 |
trailing arm suspension
So has anyone attempted to fabricate there own trailing arm suspension? If so lets see some details. Thanks
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
02-15-2006, 02:11 AM | #2 |
Until Seventy Times Seven
Re: trailing arm suspension
Quite a while back, someone on here was gonna try to swap a 73-87 body onto a late 60s chevy frame. He was also gonna swap the front crossmember/suspension from the 73-87 frame onto the 60s frame. I don't know if he made any leeway.
It's not quite what you're asking, but maybe you can borrow the setup from a late 60s rear suspension. I've entertain the offer, but there might be some interference problems between the trailing arms and the narrow frame. But, I haven't studied it enough to be sure. It does seem that a trailing arms may be a better setup then a parallel 4-link, but I'm not sure. Though, it seems a 4-link would be easier to setup. I do see alot of 4-link setups. But, in Herb Adams' Chassis Engineering book, he advises against 4-links. Maybe because of the lack of articulation. Long, near-center frame-mounted trailing arms may work out like those on the older chevy suspensions.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
02-15-2006, 09:28 AM | #3 |
I have thought about a 4-link but that wouldn't really ride that nice and would limit my handeling. I think the trailing arm set-up would be the best all-around rear suspension as it moves your IC farther forward. This will help with weight transfer. Check out Hot Rods to Hell they build these set-ups for a bunch of '60's cars.
02-15-2006, 09:47 AM | #4 | |
Happy to be here
A true 4 link (which actually has 5 links?) has as much if not more articulation than leaf springs do if set up properly. Of course "set up properly" has to include the proper length parallel bars. If these bars are too short they will have an adverse effect and cause binding as the suspension travels. Ride will not be affected by the 4 link as much as it will be buy the type of springs used. If you go with a properly set up air suspension the ride will be much better than a stock truck. Handling is also a matter of suspension design. Again with a properly designed 4 link and air suspension your handling will be greatly improved. Maybe your thinking of ladder bars...
02-15-2006, 10:55 PM | #5 |
Who makes a four link for our trucks? I still believe the trailing arm coil spring suspension would be a better solution. Do you agree with that?
02-15-2006, 11:21 PM | #6 |
All depends on what you want it to do. Hotrod had a long article about the pro's and con's of the trailing arm suspension a couple of articles back.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
02-16-2006, 12:00 AM | #7 |
i have thought of trailing arm design as well, but not for the same reason you are..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-16-2006, 01:12 AM | #8 |
My 4 link rides bettter than any trailing arm suspension truck I have been in. True I also have QA-1 coil overs with the 4 link, But it rides ohhh sooo nice!
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
02-16-2006, 01:28 PM | #9 | |
02-16-2006, 01:30 PM | #10 |
70 short/step
Where did you get your four link set-up from? It rides better bet how does it hook and handle? Although if you still don't have your bed on it may not be a fair question.
02-16-2006, 06:48 PM | #11 |
Hooks Awsome!
Handles Great! With or without the bed it rides fine! Those QA-1 coil overs have a 12 setting dial on them so you can go from no bed and it rides nice to hauling stuff and it still rides well. The 4 link is Air Ride Technologies. ValleyCustom from here on the board set it up for me. There was a link on here about the whole thing but it is gone now.
